Epoxy Filler needed? - SailNet Community
 1Likes
post #1 of 17 Old 12-07-2012 Thread Starter
Pamlicotraveler's Avatar
I am in the process of removing some handrails and reinstalling after varnishing. I think I am going to get some West Epoxy - something I have never used before. So I need some opinions on the best way to do this.
For this purpose will I need a filler to make it thicker before putting the epoxy in the screw hole. How do others do it? And which filler would I use of I am going to drill it after it dries?
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #2 of 17 Old 12-07-2012
Courtney the Dancer
jrd22's Avatar
Re: Epoxy Filler needed?
This is what I have used, works very well for potting holes.
West System 406 Colloidal Silica
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 17 Old 12-07-2012
bljones's Avatar
If you are using west system, use the 404 high density filler:
West System 404 High-density Filler
Some use 406 colloidal silica or mix it to the 404 to amp up the strength, but unless your handrails are under serious potential shock loading (jacklines, turning blocks, etc.,) it's overkill. If you're rebedding cleats, chocks, deck hardware, travellers, winches,etc., then
406 is a necessity.
To do it right, you need to do more than just wipe some goop into the existing holes. Follow the instructions here:
WEST SYSTEM | Projects | Fiberglass Boat Repair & Restoration - Repairing machined holes in fiberglass
and here:
Sealing Deck Penetrations to Prevent Core Rot Photo Gallery by Compass Marine at pbase.com
msmith10 likes this.
It's 5 o'clock somewhere:
bljones is offline
post #4 of 17 Old 12-07-2012
overbored's Avatar
West 610 already to go. just put in chalking gun and use
WEST SYSTEM SIX10 THICKENED EPOXY ADHESIVE CARTRIDGE - 190 mL from Aircraft Spruce
"GOLD RUSH" PRINDLE 16
overbored is offline
post #5 of 17 Old 12-07-2012
cookwithgas's Avatar
If you are just filling screw holes to protect the core, why not use JBQuick instead? West System epoxy makes you wait a day to dry and JBQuick will dry in five minutes. I usually drill the hole out a few sizes bigger, tape below, then fill the hole with JBQuick. Wait five minutes, re-drill the hole to the proper size and install your hardware. West System Epoxy is great and the filler works well when you want peanut butter instead of syrup but it dries slow. Just my 2cents.
cookwithgas is offline
post #6 of 17 Old 12-07-2012
I don't discuss my member
zz4gta's Avatar
I use the pumps. Makes things a lot easier. Save the pumps.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #7 of 17 Old 12-07-2012
bljones's Avatar
JB KWIK is 5-10% iron. Your stainless steel fasteners won't like it. if you're requiring a day for west to cure, use a faster hardener.
West Six10 premix is good stuff and sets fast (4-6 hours) and if you aren't going to do anything else requiring epoxy , it is a good choice.
bljones is offline
post #8 of 17 Old 12-07-2012
Courtney the Dancer
jrd22's Avatar
That looks pretty slick! I'm assuming that you have to use the whole tube (it doesn't just mix what you use)?
John
SV Laurie Anne
jrd22 is offline
post #9 of 17 Old 12-07-2012
Junior member, rest old
msmith10's Avatar
No, you don't have to use the whole cartridge. The unused portion in the cartridge will stay good. You do have to replace the mixing tip. They sell them separately.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #10 of 17 Old 12-07-2012
Senior Slacker
SlowButSteady's Avatar
Check out these guys. I've used there stuff on several projects and it's pretty good.
Clear Marine Epoxy Resins-Paints - Largest Online epoxy source;
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Can I apply epoxy filler over barrier coat? patrscoe Gear & Maintenance 3 06-15-2012 03:21 PM
Wood rot and filler weephee General Discussion (sailing related) 5 07-08-2009 07:06 PM
Wood filler/epoxy around sill SpeedAgent Gear & Maintenance 1 02-09-2009 11:47 AM
can you use epoxy filler and then fiberglass over it? saurav16 Gear & Maintenance 4 06-03-2008 02:23 PM
Using filler in epoxy saurav16 Gear & Maintenance 10 09-25-2007 01:34 PM
