Mast wiring - SailNet Community
post #1 of 3 Old 04-03-2004 Thread Starter
Mast wiring
I have a wooden mast and have been trying everything I can think of short of cutting the mast apart to run new wiring. I''ve tried bailing wire, electrician''s "fish tape," even tried using fishing line sucked down the conduit with a vacuum cleaner. No luck. Any ideas would be most appreciated!
sneuman is offline
post #2 of 3 Old 04-04-2004
paulk's Avatar
Mast wiring
What about bicycle or bead chain, or is the passage too small? ( Your mast is up, of course.)
paulk is offline
post #3 of 3 Old 04-04-2004
Mast wiring
have you already removed the old wiring? if not, why not use your old wiring to pull the new wiring through?
What sort of inside circumference are you dealing with? Is there room to thread some sort of flexible or semi-stiff plastic conduit?
Good luck with this
Rob
robmccarthy is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
