Non wood interior sole alternative - Page 2 - SailNet Community
 1Likes
post #11 of 23 Old 12-10-2012
Old enough to know better
Re: Non wood interior sole alternative
In Drake Paragon's cabin tour of a Nunsuch 26 they have starboard floors, but he does say they are hard to keep clean.
https://www.youtube.com/watch?v=wrTvbM3TGe0
miatapaul is offline
post #12 of 23 Old 12-10-2012
Old as Dirt!
svHyLyte's Avatar
Originally Posted by overbored View Post
thats the same stuff as plasteak/ loneseal but at a higher price. defender has loneseal for $10 less a running foot
Lonseal Lonwood #401107 offered by Defender is essentially the same material as that offered by Welcome Aboard. Welcome Aboard's price is $8.95/sf while the Defender price is $8.83/sf or about $0.12/sf (1.34%) better. The advantage will rest with the vendor that does not charge sales tax to the buyer, if either. Of course, being able to purchase the material by the running foot is a sizable advantage; and, Defender also sells the edge trim that can nicely finish out an installation.
FWIW...
svHyLyte is offline
post #13 of 23 Old 12-10-2012
Flooring on boats is made with the assumption that it will only be walked on on sunny weekends and a three week summer vacation, max.
Linoleum is made to be walked on 24-7,year round ,especially the industrial grade,and is far better made. From more than 2 ft away, it can be hard to tell apart from wood.
So why would you use inferior material with a higher price tag?
Brent Swain is offline
post #14 of 23 Old 12-10-2012
JimMcGee's Avatar
Because products for interior use are designed to work in a fairly narrow temperature range and are not designed to withstand the motor oil, diesel and solvents you spill when working on your engine. Most manufacturers will tell you that installation in a damp or unheated environment voids the warranty.
When you look at products designed for interior use you find that they won't hold up in a boat that sees temps from -10 to 120F. The problem is expansion and contraction with temperature, the flexibility of the fiberglass sole and its movement with temperature.
I got some samples of a couple of types of flooring and applied them to 24x24 squares of 3/4" plywood and hardboard and left them on my patio for over a year to see how they reacted to temperature/moisture changes.
NuTeak interior flooring still looks like new, even on the hardboard sample that warped badly after a year. Diesel and PB Blaster wiped off it with no staining. Most importantly it looks really good. I'm a woodworker so I'm very particular about the look. Too many products look like plastic. I'm going to try an install this spring. We'll see.
Here's their interior products.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #15 of 23 Old 12-11-2012
I noticed that Catalina is using some type of synthetic flooring in their new boats. It looks great and provides excellent grip. It's a little soft, not hard.
It looks like it would be an excellent replacement for real wood floors that have a limited life to them and require frequent maintenance (if you use the boat).
Catalina 36 MKII
Florida
HeartsContent is offline
post #16 of 23 Old 12-11-2012
JimMcGee's Avatar
It's Lonseal, SvHyLyte mentioned it above. Very good stuff from what I've read. The only downside is it comes in sheets; wonderful for builders but can be a little challenging with all the curves and cuts in a boat for a retrofit.
One of the things I liked about NuTeak is it comes in strips which is a bit easier to handle on the install.
JimMcGee is offline
post #17 of 23 Old 12-11-2012
Linoleum I put down 28 years ago is in better shape than wood or other materials I put down a few years ago.It's had lots of diesel ,etc spilled on it. In my 3 boats over 40 years, that has always been the case.
Claims it wont hold up as well as "yachtie " stuff, are a scam
post #18 of 23 Old 12-12-2012
blutoyz's Avatar
"Linoleum" is the wrong term being used. Sheet vinyl, specifically fiberglass backed sheet (ie "FLexitec, Tarkett Fiberfloor, Armstrong cushionstep) id the product to look at. It can be installed with two sided tape if you like and is a simple DIY cut in. Hatches can be trimmed for access.
Real lino will be pricey and start to smell real musty real quick I am afraid
(yes I am in the flooring business...LOL)
blutoyz is offline
post #19 of 23 Old 12-12-2012
CLucas's Avatar
Send a message via AIM to CLucas
Real-world experience with Lonseal?
Just ordered some samples of Lonseal Teak & Holly for possible use on my cabin sole. Can anyone here speak from experience as to its durability in an application such as this?
I live in the northeast (LI), so the boat (Pearson 30) does experience some temp extremes. Existing cabin sole is fine, just looking to dress her up a bit.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #20 of 23 Old 12-12-2012
overbored's Avatar
Re: Real-world experience with Lonseal?
I have some 1 foot sq samples glued to the sole for a test of wear and slip resistance when wet. seems to hold up very good. the dull finish gets the dirtiest but looks the most real. the matte finish is the slipperiest, but not that much difference. so far the gloss finish is the best for slip when wet, who knew, but it does show the scratches the most . I am thinking of using the matte finish. if I use the gloss it will require me to put gloss on all the other teak so it will look as good as the new flooring.
biggest problem I have is how to finish the edges as it is a fiberglass sole and is rolled up into the sides with a large radius. I think all the dirt will catch around the edge of the Lonseal and may start to peel up.
I have samples of all the brands of this material and it looks like it is all made by the same manufacturer all samples look identical. I would guess it is made by Lonseal as they are the only one that is a flooring manufaturer
"GOLD RUSH" PRINDLE 16
overbored is offline
Interior Wood bushrat Gear & Maintenance 23 09-30-2007 09:58 PM
Updating the interior with wood byrondv Gear & Maintenance 11 08-21-2007 12:08 AM
Wood cabin sole/floor saurav16 Gear & Maintenance 5 04-02-2007 10:50 AM
Wore interior wood trantor12020 Gear & Maintenance 0 01-08-2007 12:38 AM
interior wood finish jolly_mon Gear & Maintenance 0 01-23-2002 01:32 PM
