Sound Proofing - SailNet Community
 3Likes
post #1 of 18 Old 12-10-2012 Thread Starter
Sound Proofing
I will be putting a new Motor in my 32'ketch and figure I should soundproof the Engine room before doing so. It is a single cylinder Yanmar YSM-12 so quite noisy but has never been soundproofed. Any suggestions on products, things to keep in mind, tips etc?
superiorvoyager is offline
post #2 of 18 Old 12-10-2012
Courtney the Dancer
jrd22's Avatar
Re: Sound Proofing
Noise & Vibration Control Products
Everything you need to know about marine soundproofing. Barrier 104 works great for diesel noise, I've used it on several boats.
Faster and night0wl like this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 18 Old 12-10-2012
Re: Sound Proofing
I'm halfway through this on my Bristol. JMS Online has some good prices on the Soundown products, but still I've spent about $300 so far. I used 1" thick with the barrier, doubled up in key places for 2". (key places = cabin sole and engine compartment doors)
As the engine noise gets quieter, other noises, eg rattles, are becoming more obvious - the campanionway sliding hatch, the hasps on the lazarettes, the swim ladder, the list goes on, they all rattle. I couldn't really hear them before. I will be going around with some self-adhesive neoprene to try and stop them.
I used the pin kit for the cabin sole, as I don't want to drill holes and I don't want the insulation falling down. 1 minute epoxy from the hardware store works well to glue the pins to the substrate.
For other surfaces I'm using 1" screws with 1" OD coach washers.
EDIT : The Soundown and the Barrier 104 look similar. I couldn't easily find an online supplier of the latter, last time I looked.
MarkSF is offline
post #4 of 18 Old 12-10-2012
Re: Sound Proofing
I'm doing this as well on a Cal 29. Lotsa info available on line. Bought from a local distributor because of shipping cost. This stuff is heavy, intentionally so to muffle the sound.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #5 of 18 Old 12-10-2012
T37Chef's Avatar
Thumbs up Re: Sound Proofing
I just installed Sundown Sound & Thermal Barrier this past weekend. It is heavy and expensive, but I am hoping it will be well worth it. I purchased the 1" Thermal & Sound barrier product, see here: Soundown Sound-Stop Foam Panel
I ordered 2 ea of the 1" Panels, 1 ea of the Installation kits Sundown Noise Reduction Installation Kit and an additional mounting kit Soundown Soundown Noise-Reduction Mounting Kit I have ordered one more roll of the Mylar tape to cover some edges Soundown Mylar Installation Tape, wasn't enough to finish. The two panels were just enough to cover what I needed, however I may get one more panel to cover the top of the engine but I doubt it. My primary goal was to quiet noise and reduce heat inside the cabin so I covered the quarter berth area, front engine access panel, and forward area near the galley sink. I left the area aft of the engine open for good air circulation as recommended by the engine rep. I had not realized until I really started installing the stuff just how many little spaces were open to the cabin = noise and heat. Once I completely finish taping the edges and sealing everything I am certain we will see a drastic difference, added to that the new engine should in itself be much more quiet.
Here is a link to the installation instructions. There was a little bit of a learning curve! Once I realized I can fill in and cover some of my mistakes with scrap pieces and mylar tape, I got over the fact that a couple of my seams were not perfect, but only after using a few choice words
http://www.soundown.com/Section%203%...structions.pdf
T37Chef is offline
post #6 of 18 Old 12-10-2012
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Sound Proofing
That looks very much like fiberglass/alum foil duct board material.
Hmmmmm?
Lotsa that about the house, as I just installed a new furnace and ducts!
deltaten is offline
post #7 of 18 Old 12-11-2012
Seņor Member
PorFin's Avatar
Re: Sound Proofing
Hmmmmm?
Not really -- it's a sandwich of : foil < closed cell neoprene foam > lead.
BTW: Great looking job, Chef!
PorFin is offline
post #8 of 18 Old 12-11-2012
Re: Sound Proofing
Hmmmmm?
When you handle it, you realize the difference, this stuff is heavy - about 30lb a sheet.
MarkSF is offline
post #9 of 18 Old 12-11-2012
T37Chef's Avatar
Re: Sound Proofing
Thanks, I plan to fix the one joint/gap shown in the second picture, I know no one will ever see it once the engine is in, but I will know its there
T37Chef is offline
post #10 of 18 Old 12-11-2012
chucklesR's Avatar
Re: Sound Proofing
Any body type any of the sound absorbing paints out there?
chucklesR is offline
electronic rust proofing balamara Electronics 3 08-28-2012 06:40 PM
Engine room sound-proofing mzw Morgan 5 04-25-2012 10:41 AM
Sound Proofing lans0012 Gear & Maintenance 10 01-28-2012 02:00 AM
Hello from Desolation Sound. larrytwo Introduce Yourself 1 09-03-2011 01:26 PM
Weather proofing lazarette lids GeorgeB Gear & Maintenance 4 12-05-2007 07:30 PM
