Hull Cleaning - "the mustache" - SailNet Community
 3Likes
post #1 of 18 Old 12-10-2012 Thread Starter
We have completed travel from the Chesapeake to Florida and have gotten a substantial "mustache" on the bow. Tried standard cleaners with no success. Would appreciate advice on what has worked for others. Thank you.
Al Dashevsky
dashman is offline
post #2 of 18 Old 12-10-2012
chucklesR's Avatar
Re: Hull Cleaning - "the mustache"
Mary Kate's On Off, or any of the acidic cleaners - if you can find one go with the gel type.
You simply wipe it on and hose it off, but you might have to rewax the area. Nothing else seems to work. Wear gloves.
chucklesR is offline
post #3 of 18 Old 12-10-2012
CLucas's Avatar
Send a message via AIM to CLucas
+1 on Mary Kate. A nylon scrubbie with On&Off helps. Wear rubber gloves and cuff them so it doesn't run down your arm (ask me how I know).
Guessing though that you might be in the water... On&Off can't be good for the fishies so others may have better suggestions.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #4 of 18 Old 12-10-2012
chef2sail's Avatar
FSR works easily rub on and use gloves
DAVIS INSTRUMENTS FSR Fiberglass Stain Remove at West Marine
SecondWindNC likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 18 Old 12-10-2012
pdqaltair's Avatar
I've found it goes away one its own in a month or so. Sun and bugs I guess. It's just tanin.
I'd rather not risk the run-off and potencial paint stripping. Beside, now you look well-traveled.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #6 of 18 Old 12-10-2012
Try lemon juice. I believe you be surprised.
waterwks4me is offline
post #7 of 18 Old 12-10-2012
"Sparkie"
j34035's Avatar
Iron out. Get it at any home improvement store. Comes in powder form. Mix with water and wipe it on with a sponge then rinse. I have had good luck with it.
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #8 of 18 Old 12-10-2012
HANUMAN
RobGallagher's Avatar
It will go away on it's own after a while. I prefer that method, but I'm lazy and with what you pay for the cleaner, gloves and scrubby you can buy a round of drinks.
RobGallagher is offline
post #9 of 18 Old 12-10-2012
Señor Member
PorFin's Avatar
+1 on the lemon juice concentrate from your nearest grocery store. Fill up a cheap spray bottle from the dollar store (or a re-purposed one from the trash), and you're in business!
PorFin is offline
post #10 of 18 Old 12-10-2012
Somewhat Senior Member
mgmhead's Avatar
You'd be surprised at what a good job plain bottled lemon juice does, but for best and quickest results I use Starbrite Hull Cleaner. Spray on and rinse off with either product. Both are going to attack your hull wax, I think the lemon juice is somewhat more environmentally friendly and less harsh to the wax job.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
Tags
hull cleaning , mustache
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
Seacock Base for 1/2" thru-hull "pipe" DrB Gear & Maintenance 2 12-08-2008 01:28 PM
Hull-Scrubbing/-Cleaning "Pad" On A Pole? SEMIJim Gear & Maintenance 36 08-02-2007 08:32 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
