Like Tree17Likes
  #11
Old 12-15-2012
jrd22's Avatar
Courtney the Dancer
Re: overpropped vs underpropped
Lance- I'm not telling you what to do but using your analogy when you have your throttle wide open on the boat and you aren't able to achieve the manufacturers WOT rpm you ARE lugging the engine just like your Jeep when you have your foot in it and can't accelerate because of too much load. That extra load from too much prop/pitch is present throughout the rpm range but you can only tell when you try to reach WOT. Your engine is pulling it's guts out trying to get there but just can't (just like when you have to shift in your Jeep). By the way, your use of WOT in reference to your engine is incorrect. WOT is the manufacturers required maximum rpm under load, what you are referring to on your boat is the maximum rpm attainable with your over pitched prop at full throttle which is 600 rpm below WOT. Sorry, not meaning to go off on you, this is a very common misconception that results in various expensive engine problems. There would be absolutely no reason for the manufacturers to even bother to establish the WOT for their engines if it wasn't important.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #12
Old 12-15-2012
lancelot9898 is on a distinguished road
Thanks John for the discussion. I understand that my WOT term is not the WOT that the mfg uses. It's just the max rpm that can be achieved at a given prop pitch.
Let me try to explain in a different way. As I go up the hill in my Jeep without down shifting I will slow down with the rpm going down to zero yet when I go into a headsea/headwind that is not the case for the boat. The boat will slow down yet the engine will maintain 2500rpm. Why is that? The Jeep has no slippage in that the tires maintain firm contact with the pavement while the prop on the boat is "slipping'. In other words the pitch of the prop is set for an optimal speed. I set mine for achiveing 6 knots at 2500 rpm and can approach hull speed at "wot" of 3000 under calm conditions. I just don't want to hear the engine screaming at 4000 rpm which is the max intermittent rating and is what I can achieve under no load. While a max prop allows for setting different pitches it does not allow a variable pitch while underway. I guess we will have to agree to disagree on this and note that I'm not advocationg anybody follow me on this.
This brings up another interesting point on engine operation. In my Perkins workshop manual, it mentions replacing a zinc in the heat exchanger. There is no zinc in that heat exchanger. I found a good perkins mechanic who agreed that there is indeed no zinc since the rubber end gaskets on the end of the exchanger isolated the core from the metal of the rest of the engine. My point is that even a workshop manual can be wrong...and in some cases even I.
Best Regards
  #13
Old 12-15-2012
Minnewaska will become famous soon enough
Just to be certain, you must check WOT rpm under load. If you try to do so at the dock, in neutral, you will get a different result and its inapplicable.
When you are overpitched, you will get too low a result. I will echo that you confirm the accuracy of the tach, as they are indeed notoriously wrong. Lancelot, it could even be the case with yours.
Backpressure from overpitch is just clearly bad for a motor over the long term. Some engines will be more finicky than others, but getting way with it is like deciding to take up smoking because you know of one 90 year old that smoked their entire life.
Ironically, overpitching the prop helps maneuverability around the dock. That will probably convince some to take their chances. Being overpitched at cruising speed for a lengthy period of time, probably isn't that bad. But getting there is just like leaving a stop sign in 4th gear. Doing that thousands of times just ain't good.
Not sure why one would be fixated on cruising at a given rpm. It should be whatever the motor wants to be at proper settings. Don't like the noise? Well that's obvious, but there are no engine noises that I'm good with. Necessary evil.
Jeanneau 54DS
  #14
Old 12-15-2012
kellysails's Avatar
Puget Sound Pounder
kellysails is on a distinguished road
Regarding engine noise, ref to my last post of the change I made.
Originally Posted by kellysails View Post
@20 degrees
WOT no load 3400rpm
WOT under load 3400rpm
@22 degrees
WOT no load 3400rpm
WOT under load 3250rpm
FWIW
My wife and I both noticed that after we made the change to the prop, the engine sounded slightly different at cruising rpm. It seemed a bit smoother, a bit lower sound tempo. Oddly we thought "it" sounded "happier", not so whiny
  #15
Old 12-15-2012
jrd22's Avatar
Courtney the Dancer
Kelly- what is your engine manufacturers spec for WOT. Full governed rpm is the rpm at full throttle in neutral, the governor controls the maximum rpm to prevent damage to the engine. If you were able to reach the max governed speed under load you were either way underpropped, or you have a lot of hp. Sounds like by increasing pitch you actually put the engine under load which would make a difference in sound.
John
SV Laurie Anne
  #16
Old 12-15-2012
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
running with the greater pitch at cruising RPM gives better fuel economy & less engine wear. as long as the engine can keep the same RPM under heavier load conditions & without smoking it is not overloaded.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
  #17
Old 12-15-2012
srah1953 is on a distinguished road
I have a Yanmar 3JH5CE with SD50 saildrive. How do I know what RPM should be at WOT. The only figures I can find is that the manufacturer quotes a maximum output figure at the crankshaft which is 39hp @ 3,000 RPM. With the original fixed prop, I can get around 3,200 RPM. What does this mean in terms of being over- or under-propped?
Many thanks
  #18
Old 12-15-2012
amarinesurveyor is on a distinguished road
jrd22 has it right. I see that many still have the opinion that putting a bigger prop or a steeper pitch in your prop will reduce engine wear and save fuel, and they choose to disregard engine manufacturers and mechanics. Everyone thinks they know better. You all can do whatever you want with your boat, but I think you'll find that with the correct or slightly under-pitched prop you will get the least engine wear and the best fuel economy. Yes, with an over-pitched prop you actually burn more fuel and can't develop full horsepower.
The analogy I like to use is: having a boat with an over-pitched prop is kind of like riding you bicycle in high gear (you know how hard it is on your legs, well it's like that for the engine that is over-propped).
  #19
Old 12-15-2012
Waltthesalt is on a distinguished road
Difference between cars and marine diesels is that the diesel you control the governor and the governor controls the throttle, on a car you just control the throttle. So a marine diesel won't exceed the max governor setting. If you can't get up to RPM, also black smoke, too much pitch, if RPM gets up too quickly and hull speed is down too little pitch
Walt Elliott
Kingston WA
Puget Sound
Cal-29
  #20
Old 12-15-2012
kellysails's Avatar
Puget Sound Pounder
FYI
Yanmar 4JH5E naturally aspirated (non-turbo). Yes, we are hitting the governed rpm rate (3400 rpm). Prior to making the prop pitch change we easily hit the governed rate under load. So our yard, who does all the warranty work for Beneteau, agreed that increasing the pitch would be a worth while activity. The two degree increase really helped my speed at cruising rpm. My Max Prop actually allows 1 degree pitch changes, the yard actually thinks it could go another 1 degree, but I am happy where we are. The engine sounds happy, so I am happy. So under load WOT is 3250 from a max no-load of 3400, sounds good to me.
FYI
4JH5E is 54 hp and we have an SD50 saildrive. Beneteau Oceanis 45. 23,500 lbs.
You may post attachments
You may edit your posts
SEO by vBSEO 3.6.1
