Like Tree17Likes
  #31
Old 12-17-2012
Oaksail's Avatar
Oaksail is on a distinguished road
Re: overpropped vs underpropped
Originally Posted by TQA View Post
Coolant flow from a water pump with an impeller is linked to rpm in a linear manner over it's normal rpm range. IE double the rpm and you double the flow. RAW WATE PUMP
However flow from a centrifugal pump is NOT remotely linear. This type of pump is likely to be used to circulate coolant around the engine. At very low engine RPMs coolant circulation can be impaired.
I test pumps and fluid flowrates for a living. Centrifugal pumps and fans operate with direct proportional flow rate vs rpm.
Decrease a pump by 15% rpm and you get 15% less flow.
1989 CS30
  #32
Old 12-17-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Originally Posted by MedSailor View Post
My circumstance is a bit different as I have a screwy, older engine (Perkins 4.108) and this mechanic had messed around with my particular engine on my particular boat before. My engine is also undersized for my boat, but old, sturdy, and heard to break, so I've pitched for a slightly shorter lifespan in exchange for being ABLE to reach hull speed at 75% throttle.
Your great grand children are going to be annoyed with you.
MedSailor and lancelot9898 like this.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #33
Old 12-17-2012
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Dat not wot my text books and test results said.
Notice that larger pumps are inherently more efficient and that efficiency drops rapidly at specific speeds of 1000 or less. Jacques Chaurette p. eng.
Primary coolant centrifugal pumps would be classed as small?
However I know I am not a centrifugal pump expert.
  #34
Old 12-18-2012
Oaksail's Avatar
Hi TQA, I can't scan my text books but this might work
Try this link Downloads & CDs
You can get to it through ITT Bell & Gossett website, click on "Online Calculators" scroll down and click on 'Flow / Head - Variable Speed Pumping Wizard" and try it out.
Start at 5 gpm at 10 ft of head and then look at what happens to flow at different speeds. Directly proportional.
Try 5000 gpm at 10, 100, or a 1000 ft of head.
I test small pumps and i test BIG pumps. I test them at different speeds.
1989 CS30
  #35
Old 12-18-2012
Maine Sail's Avatar
This is very easy to see with centrifugal bilge pumps. Drop the voltage and the output is also cut. It can be pretty dramatic...
______
-Maine Sail / CS-36T
  #36
Old 12-18-2012
Brezzin's Avatar
Brezzin is on a distinguished road
Back to the topic.
Having just replaced my three blade fixed with a four blade feathering. I find that I can only get to 2900rpm with the max WOT at 3200. But I can reach hull speed easily here.
Now I almost never run the engine at WOT. Probably 99% of the time at 2500 or less because I don't care for the motion of the boat over 8 knots. The engine is a Yanmar 4jh4HTE
Is the 4 blade adding more stress to the drive train than the three and am I doing damage at this prop setting?
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
  #37
Old 12-18-2012
Minnewaska will become famous soon enough
Originally Posted by Brezzin View Post
....Having just replaced my three blade fixed with a four blade feathering. I find that I can only get to 2900rpm with the max WOT at 3200. ....
This is confusing. If your new feathering prop won't allow you to get to max rpm under load, then it needs to be adjusted. If you're uncomfortable at any given speed, just pull the throttle back. But it should be able to get to max rpm.
Jeanneau 54DS
  #38
Old 12-18-2012
jrd22's Avatar
Courtney the Dancer
I agree with Minne. It's not just that you can't reach WOT, it's that at 2500 rpm you are asking the engine to do what it normally would at 2800 rpm (approx) with less hp so it puts more strain on everything. That's not a huge difference and your engine might do OK, but if you get into a situation where you are motoring into a stiff wind and large waves and you need to run near full throttle that is when you might blow a headgasket or overheat, etc.
MedSailor and amarinesurveyor like this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
  #39
Old 12-18-2012
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
Well put. From the mechanics I've talked to, being ABLE to reach max RPM at WOT is the only real way you can tell if you have the correct amount of stress on your engine at any given speed.
How many hundreds of RPM can you fudge it and get away with? That depends on a lot of things and many unknowns. If you adjust your new prop so that you can reach max RPM at WOT and you can still hit your cruising speed at a reasonably efficient RPM then there is no downside.
At what RPM do you currently reach hull speed/cruising speed? What engine do you have?
MedSailor
jrd22 likes this.
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
  #40
Old 12-19-2012
srah1953 is on a distinguished road
Originally Posted by kellysails View Post
FYI
Yanmar 4JH5E naturally aspirated.
Hi
I note that you say your engine is a Yanmar 4JH5E and that it has a governed rpm rate of 3,400rpm. May I ask where you got this data from? The only data I can find for it from Yanmar is a maximum output rating of 53mhp at the crankshaft at 3,000rpm I'm asking because I'm trying to find a source to find out what is the maximum WOT rpm of my 3JH5E engine.
Thanks
You may post attachments
You may edit your posts
SEO by vBSEO 3.6.1
