Fresh water winterization - SailNet Community
 2Likes
  • 1 Post By Vasco
  • 1 Post By pdqaltair
post #1 of 5 Old 12-17-2012 Thread Starter
Dcneuro's Avatar
I winterized my fresh water system yesterday and found that on my new boat I can no longer blow the system out with compressed air as I did on my last boat. (I recently posted on this also, under Atlantic Marine Hot Water Tank). Alternatively, I used antifreeze. It took over ten gallons to do it. Cant this stuff be cut with water by 50% or 33%? My boat stays in the water and the water is brackish saltwater off NY Harbor in NJ. It rarely goes below 0 here and the water will never go below 32. Does anyone else do this?
Dr. S.
"Eh Winds Up, Doc?"
Bristol 32
Dcneuro is offline
post #2 of 5 Old 12-17-2012
One of None
deniseO30's Avatar
Re: Fresh water winterization
I just pump the pink stuff through untill it comes out the faucets. It only takes one hard freeze even though it seems we may never get one this winter.
My boat takes allot because I don't by pass the HWH. I did find however, I can use less AF by first draining the HWH and closing the TP valve so the AF flows in and out but makes an air bubble in the tank.
My last project!
deniseO30 is offline
post #3 of 5 Old 12-17-2012
Warm Weather Sailor
Vasco's Avatar
Drain and bypass the hot water tank. Then it'll take less than one gallon of AF.
chef2sail likes this.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #4 of 5 Old 12-17-2012
pdqaltair's Avatar
The pink antifreeze that is generally available is already cut 4:1 with water. so no, not really. Although the water stays at 32F, the cabin most likely sees mid-20s on several occations.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #5 of 5 Old 12-18-2012 Thread Starter
Dcneuro's Avatar
Therein lies the problem. I could not get it to drain. Disconnected both the inlet and the outlet, left a faucet open for air, even used compressed air. Blowing in the inlet got about a gallon of water out of the outlet, but not enough as it is uphill and just bubbled. There must be some sort of check valve as blowing in the outlet just built up back pressure. Don't know why a check valve would be in there.
Dr. S.
"Eh Winds Up, Doc?"
Bristol 32
Dcneuro is offline
Tags
winterization
Atlantic Marine Hot Water Tank and Fresh Water Winterization Dcneuro Gear & Maintenance 5 12-17-2012 11:03 AM
converting raw water head to fresh water rmeador Gear & Maintenance 17 06-02-2011 02:12 PM
Fresh Water cooling water dirty brown sailak Gear & Maintenance 17 07-31-2009 11:52 PM
Smelly water from fresh water tank Bruce_Olson Gear & Maintenance 20 09-01-2007 04:42 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
