Companion way cover - SailNet Community
post #1 of 3 Old 12-17-2012 Thread Starter
PAULCR1's Avatar
Companion way cover
My sliding companion way cover has a crack running from the aft edge for about 4 inches. It is polycarbonate. Does anyone know of a clear drying bonding agent I can use to prevent this crack from running?
Thanks
PAULCR1 is offline
post #2 of 3 Old 12-17-2012
Re: Companion way cover
You should probably drill a small hole precisely where the crack ends now... that should stop the spread of it any further. Maybe consult a autoglass shop about injecting a resin like they do with rock chips for windshields.. or take a stab at something similar yourself.
But drill the hole first.
Faster is offline
post #3 of 3 Old 12-18-2012 Thread Starter
PAULCR1's Avatar
Thanks Faster.
Going to drill the hole first to keep the crack from running but never thought about a resin. Was going to try some trichlorethlene but I know it is pretty toxic. Maybe the glass shop would be a better/safer idea.
Thanks again.
PAULCR1 is offline
Dodger windows - cover or not cover? Gene T Gear & Maintenance 17 10-12-2010 03:50 PM
companion way doors River Gear & Maintenance 10 12-31-2009 08:19 PM
Crew/Companion for BVI 01/09 AlanJC Crew Wanted/Available 10 12-01-2008 03:44 PM
C-270 Main Sail zippered cover w/ lazy jacks, "Lazy Bag", "Quick Cover" Installation randy22556 Gear & Maintenance 0 02-27-2007 05:02 PM
S.W.FL : looking for sailing companion Volkhard Crew Wanted/Available 2 03-21-2006 08:02 PM
