Extra spreader question - SailNet Community
post #1 of 4 Old 12-18-2012 Thread Starter
Hi
I have a 39 ft ferro ketch double ender. Because the boat is both a double ender and only has an 11 ft beam, the mizzen lower shrouds tend to lean in and cramp the ability to put on a dodger. If I put on even a short dodger over the companion way (on the starboard side) the shrouds don't give enough space for anyone to get by on that side if you have a lifejacket on.
The current mizzen mast is only 28 ft high and has one spreader.
I am wondering if there is any reason why I shouldn't/couldn't add a second spreader part way between the existing spreader and deck to straighten up the lower shrouds and give more room for deck-movement options when I add a dodger.
If OK, then would it be critical where the spreader went? i.e. is the a lot of calculation required to figure out where it should go?
I've dug around on the internet a bit but haven't found any answers to this.
I need to replace shrouds anyway so now it the time to modify.
Thanks for your input anyone....
Cheers
SH
Swordhors is offline
post #2 of 4 Old 12-19-2012
Re: Extra spreader question
Pictures plz
peterchech is offline
post #3 of 4 Old 12-19-2012
Bristol 45.5 - AiniA
Might the existing spreaders not be the correct length? I would talk to a good rigger for this. You don't want to mess it up.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #4 of 4 Old 12-19-2012
Moderator
Jeff_H's Avatar
Masts and rigging operate as a truss. The shrouds need a transverse angle to be effective, and if you added a spreader to make the shroud vertical that angle would be eliminated so there would be insuficient force to hold up your mast. Sorry.
What might be possible is to create a diamond shroud layout and a single upper shroud, but that would take careful engineering.
Jeff_H is offline
Spreader question Stevyboy Gear & Maintenance 7 02-09-2011 10:25 PM
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 08:25 AM
yet another spreader question Gorlog Gear & Maintenance 3 04-27-2007 11:51 PM
spreader/mast rake question Gorlog Gear & Maintenance 2 04-27-2007 02:30 PM
