Winterizing With Brine - SailNet Community
post #1 of 11 Old 12-22-2012 Thread Starter
pdqaltair's Avatar
I've been running down facts and doing some materials testing relating to winterizing with glycols. There are some down sides, principally that certain plastics don't relate well to PG; Some harden, some crack. I believe this is a more common contributor to deterioration than most realize.
What about brine? Commonly used to winterize certain equipment and wooden boat bilges from what I hear (no personal expereince) and benign to all elastomers and hard plastics that I can think of, what are the down sides for the head, for example? Harmless to the environment and POTW. Certainly corrosion to metals, even stainless, may be enough to make this a non-starter, but real world experiences would be interesting.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #2 of 11 Old 12-23-2012
Liquorice's Avatar
Re: Winterizing With Brine
OK I'lll bite - what the f*#k are you talking about!
sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #3 of 11 Old 12-23-2012
chef2sail's Avatar
He wants to run pickle juice through his fresh waster system to winterize
Seriously though. Brine solutions which are increased concentrations of salts in water.
Increasing the salt level can be corrosive to metals such as hot water tanks, maybe metal components of pumps, impeller shaft. I think Ill stay with the pink stuff.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #4 of 11 Old 12-23-2012
You would have to dissolve a serious amount of salt to make much difference. Sea water, for example, will freeze at 28 F. Saturated salt water, where it won't dissolve any more solids, will protect below 0 F, if I'm not mistaken. That's approx 1 part salt to 2 parts water, but I don't think it will do as well as the basic -50 F anti-freeze.
I will admit that I like the thought of a product you might put in your fresh water system that has no chemicals. I'm wondering how long it would take to flush out, since adding more water will just continually dillute the salt water. Of course, the corrosive affect could be very bad on fixtures.
Jeanneau 54DS
Minnewaska is offline
post #5 of 11 Old 12-23-2012
I have seen it done in bilges before but nowhere else. It was incredible how well it showed all of the little component that were not made of a corrosion proof material. In the spring, there were a lot of salt crystals in the bottom of the bilge which I would not want to try to send through the bilge pump. It may have been that the solution was not properly mixed, I did not see it put in. The one problem that I noticed is that the boats doing it seemed to eat through bilge pumps really fast. Purely guessing, I would think that the shaft seals were being compromised either by the salt or corrosion on the shaft allowing salt water into the motors.
If you concern is putting non toxic antifreeze in your fresh water, a lot of people put very high proof alcohol in their water systems. I have no first hand experience with this because I have always been able to drain water systems and leave them dry. It would be worth looking into what temperature this would protect to.
klem is offline
post #6 of 11 Old 12-23-2012 Thread Starter
pdqaltair's Avatar
Let me be clear; I think brine is generally a really bad idea for most folks. I just felt like a discussion.
The main reason it would make sense in certain wooden boat hulls is that while the corrosion is bad, the rot that freshwater and PG or EG would trigger could be fatal. The practice started before boats even had engines to rust. Better to keep the wood pickled with salt. This logic means nothing to FRP boat owners.
Freeze point is easy to google. More than likely, they just poured in some rock salt and let leaks do the rest.
http://seagrant.oregonstate.edu/sgpu...ubs/h99002.pdf
Ethanol is not good for nitrile, urethane or pvc (including soft vinyl tubing). In the case of a head, if you are using white sanitation hose I promise that ethanol will cause odor permeation to begin within 1 year (I did the testing) making this a terrible idea. If the head has nitrile joker valve and flapper (Raritan and Groco), they will get hard and crack after a few years. I wouldn't be too surprised if the alcohol evaporated out of the bowl, leaving only frozen water. While people do the darnedest things and often get away with them, that is not a general solution either. The manual also warns them not to.
post #7 of 11 Old 12-23-2012
Bluenoser
jimjazzdad's Avatar
Make up an adaptor to connect the outlet of your ShopVac to your fresh water system Blow the system clear with air. This is how I used to winterize swimming pools up here in the Great White North. Never had a problem. When I replumbed my boat, I made it so I could drain the system. BTW, I would avoid brine or glycol in the FW system.
jimjazzdad is offline
post #8 of 11 Old 12-23-2012
RichH's Avatar
Seawater is only 3-4% salt.
The max. freezing point depression with ~20% salt (saturated solution, adding any more wont 'dissolve') added would be -21°C/ -6°F
100 proof vodka (-50% ethanol) will get you to -25°F. Only problem with 100 proof vodka is its 'flash point' is near 75°F and therefore starts 'delivering' an easily combustible gas phase.
RichH is offline
post #9 of 11 Old 12-23-2012
I have a city water hose inlet on the boat, which is at the end of the fresh water system. I just screw in a brass coupler that changes it to a stem fitting, like an inner tube. Then I attach a small compressor with a locking tire chock that can deliver a continuous 35psi. Open all the faucets one at a time and blow it all out. Easy peasy.
Jeanneau 54DS
post #10 of 11 Old 12-23-2012 Thread Starter
pdqaltair's Avatar
Howzat work on the head?
Sorry, just had to say it, the metal image was powerful. Yes, it is a good method for the potable system, but I did start the thread talking about the head.
Winterizing AlanInSeattle Gear & Maintenance 26 01-02-2010 10:46 AM
Watermaker brine discharge question Zanshin Gear & Maintenance 9 05-12-2009 03:09 PM
Winterizing Popsbear Newport 0 11-08-2007 09:33 PM
winterizing timangiel Seamanship & Navigation 17 10-31-2006 03:55 PM
Winterizing drynoc Gear & Maintenance 4 11-24-2005 02:35 PM
