Edson Pedestal Paint? - SailNet Community
 11Likes
post #1 of 31 Old 12-23-2012 Thread Starter
T37Chef's Avatar
Question Edson Pedestal Paint?
I'm looking for suggestions for painting an Edson pedestal. I initially was going to have it powder coated but I don't see the need?
I believe it's an aluminum housing, Edson uses a baked on Urethane Finish. Do you think I must use a "marine" type finish such as Interlux Perfection or Brightside, or would something compatible with aluminum from a hardware store work fine? I suppose the two part Perfection paint would be the most durable next to powder coating?
What have you used and liked?
Also, my compass (Ritchie) has some distortion on the glass, any suggestions for having it refurbished? Where/who?
I need to replace the aluminum bolts, Edson sells them @ $12.00 a piece, wtf? http://www.edsonmarine.com/marinesto...oducts_id=1152
Thanks
T37Chef is online now
post #2 of 31 Old 12-23-2012
Tartan 37C
T37SOLARE's Avatar
Re: Edson Pedestal Paint?
J. Gordan & Co in Eastport is the Ritchie repair specialist in Annapolis J Gordon & Co - Annapolis, MD - Complete Marine Solutions - Boat, Yacht, and Marine Services and Repairs Had mine rebuilt a few years ago, they did a great job at a good price.
T37Chef likes this.
SOLARE
T-37 #442
T37SOLARE is offline
post #3 of 31 Old 12-23-2012
Courtney the Dancer
jrd22's Avatar
You might check at an automotive paint store. I had to make a new support for our binnacle guard and had the shop match the color of the pedestal. They had a primer for aluminum and a clear protective coat finish to go over it (spray cans). Much more durable products than regular spray paint. You might be able to find a stock white that matches the Edson, I had to have a custom spray can made up which was more expensive, but still not too bad.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is online now
post #4 of 31 Old 12-23-2012
One of None
deniseO30's Avatar
I used white brightsides on mine.. I did wipe it down and scrub it real well with 400 grit w/d paper. 3 yrs now it's moldy but not pealing in anyway.
My last project!
deniseO30 is offline
post #5 of 31 Old 12-23-2012
Edson has paint that matches the original. All I needed was some touch up and they gave me a small bottle at the Annapolis boat show a couple years ago. It was a one part paint in a small bottle with a brush built into the cap. The color match was perfect. It is actually hard to match white paint.
harbin2 is offline
post #6 of 31 Old 12-23-2012
72 C&C Corvette
CorvetteGuy's Avatar
Did the same as Denise, 5 years later still cleans up to new, a few scratches here and there but happy with the results
CorvetteGuy is offline
post #7 of 31 Old 12-23-2012
Over Hill Sailing Club
smurphny's Avatar
When I removed the pedestal during the re-core of the deck three years ago, I sanded it off well, down to 400 grit, primed it with Rustoleum and painted with white semigloss Rustoleum flit cans. It has held up well so far. Guess I could have broken out the spray gear and spent a lot of money on Awlgrip or even a good automotive paint but for about $15, the thing looks good.
smurphny is offline
post #8 of 31 Old 12-23-2012
Sabreman's Avatar
I'll second the Rustoleum tip. I used Rustoleum Industrial white on my Edson Binnacle base and on the Bomar Hatches. I sanded to 220, then 320 grit, wiped with lacquer thinner and then primed with Rustoleum Industrial primer. No flaking or fading after 4 years. Wonderful stuff, cheap and available at the big box stores.
Sabre 38 "Victoria"
Sabreman is offline
post #9 of 31 Old 12-23-2012
chef2sail's Avatar
Our Edson Binnacle is the old style black. I used the is Interlux Brightside and only bought one quart and applied it with foam brushes while in place. Did this last May and looked great through the season and looks like new still.
INTERLUX Brightside One-Part Polyurethane Paint with Teflon at West Marine
I also second J Gordon on the Ritchie repair. I took mine there and for less than $100 they reconoditioned it to new.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #10 of 31 Old 12-23-2012
steve77's Avatar
Thanks
I may be looking at painting mine this Spring too. Have you seen this?
http://www.edsonmarine.com/support/eb95345.php
steve77 is offline
Edson wheel removal from pedestal ambianceack Gear & Maintenance 7 04-22-2013 03:37 PM
Edson Pedestal Instrument Mounts thisisus Gear & Maintenance 2 05-05-2009 04:53 PM
Converting Edson Round Pedestal Gauges to Tack Ticks Lancer28 Gear & Maintenance 10 04-21-2008 12:20 PM
Edson experts Please help! deniseO30 Gear & Maintenance 6 04-07-2008 08:11 PM
Wiring GPS: pedestal or pedestal guard? geary126 Gear & Maintenance 14 05-17-2007 03:43 PM
