Like Tree8Likes
  #11
Old 12-23-2012
Lake Superior Sailor's Avatar
Lake Superior Sailor is on a distinguished road
Re: Frozen Bilge
Place something in your bilge ,like closed cell foam to take the crush from the ice,make sure it's jammed in and not floating!......Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
  #12
Old 12-23-2012
Re: Frozen Bilge
Originally Posted by AdamLein View Post
Actually...
Originally Posted by wikipedia
Other substances that expand on freezing are silicon, gallium, germanium, antimony, bismuth, plutonium and also chemical compounds that form spacious crystal lattices with tetrahedral coordination.
Under no circumstances should you allow your bilge to fill with liquid plutonium.
... I stand corrected....
  #13
Old 12-23-2012
caberg's Avatar
caberg is on a distinguished road
Re: Frozen Bilge
Not clear why you cant look for/address the source of the water now??
Mostly because nothing would cure in sub freezing temps. I have the whole boat tarped, and I really don't know where the water's getting in. The tarps aren't perfect, but I was very surprised to see that much water in the bilge. All summer I'd never have more than an inch after a week on the mooring even with a big rain. The windows do weep, but I think there must be something else going on.
  #14
Old 12-24-2012
chef2sail's Avatar
chef2sail will become famous soon enough
Re: Frozen Bilge
Did you drain hot water heater? Refrigerated box drain?
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #15
Old 12-24-2012
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
Re: Frozen Bilge
btw did you know that water is the only substance that expands (and loses density) when turning from liquid to solid??
Good thing, too! Otherwise our fw would never thaw out! I like having my ice cubes float!
Installing a garboard plug is much simpler than doing a floor rebuild like the beautiful work Faster did. The sleep returned is more than worth the effort.
Down
  #16
Old 12-24-2012
SailSnail is on a distinguished road
Re: Frozen Bilge
I think it will be alright just don't let it fill with water as fella says above it will allow room to expand.
  #17
Old 12-24-2012
smallboatlover's Avatar
Huck
smallboatlover is on a distinguished road
Re: Frozen Bilge
Im haveing the same problem with rain water getting in nothing has froze yet tho. last time i went i had 5 gallons of water. I just keep checking it every few days. The boats still in the water and will be for the winter. i think antifreeze might help me a little
16' mistral sailboat, And 27' coronado
  #18
Old 12-24-2012
CarbonSink62's Avatar
Load Bearing Member
CarbonSink62 is on a distinguished road
Re: Frozen Bilge
My boat sat uncovered for 3 years before I came along. The water was an inch below the cabin sole and frozen solid when I got there. This boat has a cabin liner and if the water had gotten much higher the boat would have been toast.
I threw some 'pet safe' ice melt on top of the ice and came back a week later to pull some 16 gallons of water out of the bilge. I worried and fretted about what the ice might have done, but I found no issues.
Ken
Zen Again
Catalina 25 #2818
Tide goes in, tide goes out. Never a miscommunication. You can’t explain that.
  #19
Old 12-24-2012
Maine Sail's Avatar
Re: Frozen Bilge
Originally Posted by chucklesR View Post
As long as you don't let it fill with water and therefore allow room to expand it won't break anything.
Leave the covers off and the bilge pump powered (provided you have a recharge method).
NO!!!!! I have seen far too many melted & blistered bilge pumps that nearly burned entire marinas down. Powering 12V into a stalled pump creates heat. Enough heat to melt the pump or potentially start a fire. Please do not leave a bilge pump connected to a 12V source if there is potential for freezing... This is but one of the many reasons most boat yards, and their insurers, stipulate that batteries must be disconnected while boats are on the hard
Best bet is to visit the boat regularly during warm spells and manually drain it.. Adding some PG wont hurt and may drop the slush/freeze point slightly, unless it gets to diluted by incoming fresh water.. A garboard drain is a good option if your bilge lends well to its installation..
______
-Maine Sail / CS-36T
  #20
Old 12-24-2012
lancelot9898 is on a distinguished road
Re: Frozen Bilge
I have a keel stepped mast and there is some water coming in through the interior of the mast into the bilge depending on the rain direction. I haven't read through all the posts, but maybe the tarp is directing the water into your mast if it's keel stepped.
You may post attachments
You may edit your posts
Frozen bilges Minnewaska Gear & Maintenance 15 01-25-2011 02:28 PM
Frozen Water in Bilge brob76 Gear & Maintenance 18 01-22-2010 08:15 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Frozen Bilge Water -- Issue? maddata Gear & Maintenance 13 02-09-2009 09:36 PM
Frozen Sea **** Pub911 Gear & Maintenance 26 12-11-2007 12:22 PM
SEO by vBSEO 3.6.1
