Frozen Bilge - SailNet Community
 8Likes
post #1 of 22 Old 12-23-2012 Thread Starter
caberg's Avatar
Frozen Bilge
I was up to check on the boat this morning (on the hard) and found the bilge filled with about 6 inches of liquid and frozen. I think I'm OK for now, as only the top inch or so was frozen and I was able to break it up and manually pump it out, and then I poured in a gallon of anti-freeze and pumped some of that through the system. In October I had done the same, and I think that's what kept the bilge from freezing solid as a rock. Obviously, water is getting in somewhere, but that's not something I can investigate and fix now.
My question is, if the bilge freezes through solid, what do you do, and how much of a problem is that? Is the expansion of the ice going to cause issues? The only thing in the bilge is the hose from the manual bilge pump, otherwise it's just an empty fiberglass hole.
caberg is offline
post #2 of 22 Old 12-23-2012
Re: Frozen Bilge
It could blow out the sole and/or but less likely a bulkhead. That happened to a boat i bought (reason I got it cheap)
dtwofoot is offline
post #3 of 22 Old 12-23-2012
chucklesR's Avatar
Re: Frozen Bilge
As long as you don't let it fill with water and therefore allow room to expand it won't break anything.
Leave the covers off and the bilge pump powered (provided you have a recharge method).
dtwofoot likes this.
chucklesR is offline
post #4 of 22 Old 12-23-2012
72 C&C Corvette
CorvetteGuy's Avatar
Re: Frozen Bilge
Have you ever seen a broken icecube tray?? Just need a bigger glass and more rum
CorvetteGuy is offline
post #5 of 22 Old 12-23-2012 Thread Starter
caberg's Avatar
Re: Frozen Bilge
OK, good points. I don't think I'll have a problem with it filling all the way, and I do leave the cover off. Hopefully, we starting geting snow anyway, instead of rain followed by cold weather.
On a brighter note, my tarp job has held up nicely, despite wind gusts approaching 70 mph this past Friday. (We had a wind gust of 125 mph on Mt. Mansfield!)
caberg is offline
post #6 of 22 Old 12-23-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Frozen Bilge
Back in the wood boat days we used to put rock salt in the bilge. I don't know if that would be healthy for a glass hull but it would probably work if it did not chemically damage the glass. Keeping the water out in the first place is a better idea.
smurphny is offline
post #7 of 22 Old 12-23-2012
Junior member, rest old
msmith10's Avatar
Re: Frozen Bilge
I think all boats should have garboard drains. My last boat had one but my current boat doesn't-- yet.
jimjazzdad likes this.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #8 of 22 Old 12-23-2012
Re: Frozen Bilge
Not clear why you cant look for/address the source of the water now???
Water freezing in an enclosed space can quickly generate incredible pressure.. but in a bilge it's like, as mentioned, a 'big ice cube tray.. as long as there's space for the expansion you should be fine. But I'd be looking to stop the leak!
btw did you know that water is the only substance that expands (and loses density) when turning from liquid to solid??
Faster is offline
post #9 of 22 Old 12-23-2012
Re: Frozen Bilge
Insofar as it has space to expand upward, I don't see there being a problem.
Rockter is offline
post #10 of 22 Old 12-23-2012
AdamLein's Avatar
Actually...
Originally Posted by wikipedia
Other substances that expand on freezing are silicon, gallium, germanium, antimony, bismuth, plutonium and also chemical compounds that form spacious crystal lattices with tetrahedral coordination.
Under no circumstances should you allow your bilge to fill with liquid plutonium.
Faster, SVTatia, chef2sail and 2 others like this.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
Frozen bilges Minnewaska Gear & Maintenance 15 01-25-2011 02:28 PM
Frozen Water in Bilge brob76 Gear & Maintenance 18 01-22-2010 08:15 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Frozen Bilge Water -- Issue? maddata Gear & Maintenance 13 02-09-2009 09:36 PM
Frozen Sea **** Pub911 Gear & Maintenance 26 12-11-2007 12:22 PM
