  #11 (permalink)
Old 04-23-2004
mcycles is on a distinguished road
Replacing Halyards
I have the same situation you do. ''82 Dehler DB1 3/4 ton IOR boat, very tapered fractional bendy mast, and a bank of 3 sheaves for the center jib and 2 wing wire halyards. All the jib halyards were fraying badly and needed replacing.
I checked the sheaves and they are not the U-channel groove style suitable for only wire, nor are they abraded badly... and my 8mm (5/16") Validator II replacement line appears to fit nearly perfectly in them... which means it is probably larger than optimal size for that sheave diameter. The old wire halyards were 3/16".
Still, I am going to run it for this summer season and see how things go. I tied on my shackles w/ buntline hitches, the line strength is rated at over twice what the old (and fraying) wire was, so I anticipate no problems with that. I am not stripping the cover, mainly for longevity but also for added protection since i''m not absolutely certain there will be no chafe issues.
  #12 (permalink)
Old 04-23-2004
Replacing Halyards
replacing fuel tanks newby1018 General Discussion (sailing related) 0 05-01-2004 10:40 AM
Replacing a headliner bayme Gear & Maintenance 6 02-13-2003 04:56 AM
replacing deck non-skid gto2 Gear & Maintenance 4 08-22-2002 03:47 PM
Replacing Holding Tank ABullard Gear & Maintenance 1 08-15-2002 09:11 AM
replacing inboard engines rjk Gear & Maintenance 2 05-09-2001 07:29 AM
