Old 12-27-2012
jhgreen is on a distinguished road
small crack at the base of the mast
Hello
I went to my yard the other day to schedule my winter maintainance and ask how my mast removal went i was told i have a small crack running up my mast how serious is it and will it excede 1500 the cost of another mast for my boat, i found a used one if it comes to that
Jeremy
Pearsom10m
  #2
Old 12-27-2012
Re: small crack at the base of the mast
Definitely need pictures on this one....
  #3
Old 12-27-2012
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
Pics. help a lot.
FWIW, If you have it welded (aluminum?) it has to be "stop drilled" before any welding is done, IF it can be welded.
o--------------o they drill a small hole at the far ends of the crack so it can't travel any more.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
  #4
Old 12-27-2012
Flybyknight is on a distinguished road
Why did it crack? and what's to prevent a replacement from cracking?
If it were my problem, I would weld up the crack and weld in a reinforcement sleeve. imho.
Dick
  #5
Old 12-28-2012
I was told by the yard i have not seen it myself otherwise i would have taken piçtures - it îs stored for the winter so i can't get to it
It is aluminumum and i believe it may habe simething to do with being keel stepped
Jeremy
Pearson 19m
  #6
Old 12-28-2012
Stumble is on a distinguished road
Jeremy,
It is generally a terrible idea to weld masts. To some extent it is possible to do so if the weld is in a non-critical area and far up the mast (where loads are lightest). In this case it's right at the mast step which is the highest load section. I hate to break it to you, but the only way to weld this would be to weld it up, then heat treat the entire mast again to bring it back up to whatever heat treatment schedule it currently is.
6000 series aluminium (which is almost all masts) is heat treated to 400F and held there for hours. This imparts a lot of the mechanical strength of the part. When you weld a 6000 series alloy it looses all of the mechanical properties of the heat treatment, and can loose as much as 40% of the original strength.
You might be able to sleave the area and reinforce it, but without pictures it's hard to say.
Greg Rubin
Titanium Salesman
  #7
Old 12-28-2012
tap tap is offline
tap is on a distinguished road
Wouldn't the weld, while only 60% as strong as heat treated aluminum, still be stronger than a crack?
  #8
Old 12-28-2012
Tap,
Actually it may not be. It is completely conceivable that the mast with the crack is actually stronger than it would be once you weld it (obviously it may also not be). Sleaving here is one option, replacement is the better option. Welding is at best an acceptance that the mast is not up to design strength by a significant amount, and is getting close to the designed safety margins.
Greg Rubin
Titanium Salesman
  #9
Old 12-29-2012
Hudsonian is on a distinguished road
When I've seen this it has been because of corrosion on the inside of the mast base. If the crack is short -- say 1/2' -- you may want of cut of the base of the mast.
  #10
Old 12-29-2012
Rockter will become famous soon enough
Need a picture!
You might be able to weld it.
You may post attachments
You may edit your posts
How to repair very small crack in Escape Rumba (13' plastic sailboat)? DanielF Gear & Maintenance 10 05-30-2012 05:38 PM
Possible Mast crack olddog60 Gear & Maintenance 10 12-23-2011 06:35 PM
Crack in the mast! What should I do?? adell50 Gear & Maintenance 21 06-21-2011 08:14 PM
Hairline crack on mast WebSurfer3000 Gear & Maintenance 12 07-27-2010 09:37 PM
Small crack and rust stain on the side of the keel ichorniy Gear & Maintenance 8 01-11-2009 04:11 PM
SEO by vBSEO 3.6.1
