Anchor Wars - Page 4 - SailNet Community
 27Likes
post #31 of 92 Old 12-30-2012
Re: Anchor Wars
Actually, Mantus has made a number of different test videos. On one of his website pages, you will see tests using a winch on a truck with a chain/rope rode on the anchor to illustrate the holding power in that particular bottom. In another video, he summarizes the test results in three different bottoms giving the holding forces achieved in those tests. In those tests, you would have to say that Mantus was all around better. We've been a bit hard in some of our criticisms and those criticisms might be resolved a bit by reviewing all of the test series presented at this link, especially those in typical anchoring conditions:
....Test Videos | MantusAnchors
When I try to post the link above, it comes out different from what the page shows. Type in this link.
www.mantusanchors.com/test-video
NCC320 is offline
post #32 of 92 Old 12-30-2012
Re: Anchor Wars
Agree with NC, I think Mantus is just trying to show their anchor will set in conditions that the others wouldn't, realistic or not. Add some chain and the others may set better than without.
Paul T
dabnis is offline
post #33 of 92 Old 12-30-2012
Re: Anchor Wars
Honestly, I think you guys are being a little obstinate. The video seemed like a fair comparison to me in terms of what was being shown. Was it "scientific"? No...it's a dude on a beach in shorts dragging anchors around on a short line for crying out loud. But you can't deny that for those conditions shown, the Mantus was pretty consistent in setting where the others weren't.
Mantus - a word of advice, you'll never win if you go down this road.
Good advice to Mantus. You can't video your own test and defend it. If there was a single attempt where the Mantus didn't bite, would it have made the edit?
Obstinate? Not really. I think its a good anchor, just like all the new-gen anchors. It's just a bad idea to film yourself to try to prove anything.
I'm still waiting for the vid of Smack flying one hull of Fiasco in the air, with a drink in one hand and the tiller in the other. But I ain't believing it's the first attempt......
smackdaddy likes this.
Jeanneau 54DS
Minnewaska is offline
post #34 of 92 Old 12-30-2012
billyruffn's Avatar
Re: Anchor Wars
What's it made of? Why are they bolting the component pieces together? Not sure I'd want to trust my boat to a bunch of nuts! (No pun intended).
billyruffn is offline
post #35 of 92 Old 12-30-2012
Jiminri's Avatar
Re: Anchor Wars
My 4,500 pound lead keel is held on by bolts. I've never lost sleep worrying that it would fall off.
Jiminri is offline
post #36 of 92 Old 12-30-2012
blt2ski's Avatar
Re: Anchor Wars
Saw a new anchor two with weld joints that would be suspect awhile back.
Reality is, nuts/bolts or weld joints, either if not done correctly can and do fail. I would trust nuts and bolts before welds for many items. Hopefully, if one uses one of these as a storm anchor, as a few have bought them, they have time BEFORE the storm hits to tighten/torque the nuts/bolts to a proper spec and they should hold just fine. I would worry about other items on my anchoring system before nuts and bolts holding the anchor together. Like the rope rubbing on something below I can not see and breaking, the shackle tween the chain and anchor/ or chain and rope if the latter is not spliced. Maybe even the cleats on the deck!
Then I digress..........the fellow local with a mantus that went thru some 60 knot winds has a 65lb unit for a 40 or so foot boat, that is probably around 20K as he has it loaded. It did drag once, but personally, I would put it on operator error over the anchor itself, along with potentially some other issues beyond the scope of the anchor.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #37 of 92 Old 12-30-2012
billyruffn's Avatar
Re: Anchor Wars
Point taken, but somehow I think I'd rather have forged steel vs nuts and bolts.
post #38 of 92 Old 12-30-2012
Senior Moment Member
SloopJonB's Avatar
Re: Anchor Wars
Originally Posted by Mantus Anchors View Post
We certainly could, and we might... The truth be told that no matter what we do people are naturally sceptical and will certainly question our claims and challenge our video presentations. Chain certainly improves virtual scope via the centenary effect and thus improves setting ability.... And though I know that in this particular location the above anchors will not set with/without chain.... What our aim was is to show in the video that even in the worst conditions "no chain", "short scope", "very hard bottom" and the anchor still "SETS"
The parameters you were testing were very valid IMHO - being able to operate on short scope is an extremely valuable trait for an anchor.
I would recommend that you be more careful with your video work to ensure that all tests are viewed or presented the same - seeing one anchor being pulled with the tester, rode and anchor all in full view and another where only the anchor can be seen can lead to skepticism in the viewer.
SloopJonB is offline
post #39 of 92 Old 12-30-2012
SloopJonB's Avatar
Re: Anchor Wars
That was thoroughly discussed a while back. The ability to break it down and store it flat can be a big advantage to many.
Bridges and airplanes are bolted together. I agree that at first glance, a one piece forging intuitively seems stronger but it really isn't so.
post #40 of 92 Old 12-30-2012 Thread Starter
Vendor
Mantus Anchors's Avatar
Re: Anchor Wars
Dear Netters, I feel like you are a family... Some members are at times problem children but I love you all nontheless So I wanted to disclaim that whatever anchor you have, you should be proud of it and defend it it is your right! But if you are in the market for a new boat present, check this video out....
eherlihy likes this.
Anchor Purveyor
Mantus Anchors is offline
Anchor Wars - In Search of the Lost Truth. tdw Gear & Maintenance 214 03-28-2012 06:04 AM
O'Rourke, others top Spar Wars (Island Packet) NewsReader News Feeds 0 08-15-2006 01:15 AM
Star wars bar colehankins General Discussion (sailing related) 2 09-12-2003 05:41 AM
