Anchor Wars - Page 6 - SailNet Community
 27Likes
post #51 of 92 Old 12-31-2012
Re: Anchor Wars
Manufacturers have been recommending anchors that are too light for marketing reasons for a long time.
If anchor A recommends a 40 lb anchor for my boat and anchor B recommends a 30lb anchor. Then a lot of people, sadly, believe anchor B must be better.
This creates a lot of commercial pressure for anchor manufacturers to recommend very light anchors. Mantus are to be congratulated for resisting this pressure and giving cruising sailors honest advice.
Mantus Anchors likes this.
noelex77 is offline
post #52 of 92 Old 12-31-2012
Learning the HARD way...
eherlihy's Avatar
Re: Anchor Wars
The rule of thumb is; 1lb of anchor for every foot of monohull boat length.
eherlihy is online now
post #53 of 92 Old 12-31-2012
Re: Anchor Wars
I think as you start to get above 40ft, the weight and windage start to increase exponentially and so does the necessary anchor weight. We have 75 lbs hanging off the roller right now and that's considered an avg weight, not excessive.
Jeanneau 54DS
Minnewaska is offline
post #54 of 92 Old 12-31-2012
Remember you're a womble
PaulinVictoria's Avatar
Re: Anchor Wars
Where are the anchors manufactured? I'm sure it was covered many moons ago in other Mantus threads but I'm lazy.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #55 of 92 Old 12-31-2012
Senior Moment Member
SloopJonB's Avatar
Re: Anchor Wars
Why would a manufacturer recommend an undersize anchor? Heavier is more expensive so more profit and lighter creates the possibility of some sort of failure.
I've found that manufacturers specs are frequently VERY conservative - over the top for all but world cruisers.
SloopJonB is offline
post #56 of 92 Old 12-31-2012
Re: Anchor Wars
See post 45 by Alex W.
It suggests the anchor is better.
Most cruising sailors go up 1 sometimes 2 sizes from the manufactures recommendation.
Those that stick to the manufacturers recommendation are, usually, rarely anchoring overnight.
Your avatar sugests your anchor is too heavy
eherlihy and SloopJonB like this.
noelex77 is offline
post #57 of 92 Old 12-31-2012
SloopJonB's Avatar
Re: Anchor Wars
Yeah - so much for sailing it out.
post #58 of 92 Old 12-31-2012
blt2ski's Avatar
Re: Anchor Wars
"MOST" manufacture recommendations are for winds up to 40 knots. THey then recommend a size or two up if you have a heavy windage boat, and if in storm/hurricane conditions, also a size or two up. You can look at some of the sites, Danforth IIRC has size recommendations for 20, 40 and 60 knot winds. The more the wind, the heavier the anchor, along with fluke size to hold better.
I doubt that too many recommend an anchor that is too small per say, that would open up the rear for another hole to be drilled into if you will. Then they also can not predict ALL types of conditions, 40-50' waves vs 4-5' waves in 60 knot winds on an open ocean beach area vs here in puget sound. Possibly a 10 knot current going with a 60 knot wind! One has to personally adapt the size and type of equipment for the use they will run across.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #59 of 92 Old 12-31-2012
no longer reading SailNet
Alex W's Avatar
Re: Anchor Wars
The argument here is that Rocna is undersizing their anchors and that I should step up a size. However everywhere else on sailnet people seem to think that their recommendations are accurate. They certainly provide the most detailed information on what conditions they are making those recommendations for.
I have upsized my anchor purchases in the past, but that was for a Lewmar Claw on a smaller boat where Lewmar provides very few details on what conditions their recommendations apply to. I do sleep on the boat while it's on the hook, and not always in the most calm conditions. I want a good anchor, but I don't want to carry around, haul up, or pay for extra weight if it is unnecessary.
I'm surprised and disappointed that Mantus found my query to be dismiss-able. It doesn't give me a lot of confidence when purchasing their product, which seems to be entirely against the point of them starting this thread. However I'm now very unlikely to buy a Mantus anchor and will step out of this thread.
Alex W is offline
post #60 of 92 Old 12-31-2012 Thread Starter
Vendor
Mantus Anchors's Avatar
Re: Anchor Wars
Alex, my apologies I was not trying to be dismissive at all!!!! I thought you made a decision and had your mind made up and your arguments are solid...
We just disagree with Rocna on what conservative means that's all. I have seen boats drag... in the worst of situations. I was in Panama once and friend was on a 40 foot boat using a 45 lbs Manson Supreme 6:1 scope all chain and he popped out and had to re anchor in 35 knot gust situation when the harbour got bit exposed and had 3 footers crawling through it..... I have seen a boat end up on a reef when using an appropriately sized Spade... These are all awesome anchors... but in loose bottom all bets are off...
So I am sorry if I offended, I just did not want to be pushy proving a point....
Greg
Anchor Purveyor
Mantus Anchors is offline
Anchor Wars - In Search of the Lost Truth. tdw Gear & Maintenance 214 03-28-2012 07:04 AM
O'Rourke, others top Spar Wars (Island Packet) NewsReader News Feeds 0 08-15-2006 02:15 AM
Star wars bar colehankins General Discussion (sailing related) 2 09-12-2003 06:41 AM
