Perfection Plus - SailNet Community
 6Likes
post #1 of 18 Old 12-29-2012 Thread Starter
Perfection Plus
Anyone used the stuff? I have Bristol Finish on my cockpit table and need to build it back up. I don't want to have to strip it to zero and think this will bond on top. The current finish is in good shape, I just need to topcoat and polish. Although, I would probably build this several coats, so that the polishing didn't get down to the Bristol. Thoughts?
Perfection Plus Yacht Varnish | Interlux
Jeanneau 54DS
Minnewaska is offline
post #2 of 18 Old 01-24-2013 Thread Starter
Re: Perfection Plus
While no one seemed to be familiar with this product, I'll give an update.
First, I sanded down the Bristol Finish to near nothing. I left the color, but zero gloss, as the Perfections Plus is simply clear. The prepared teak just appeared like a satin stain.
Then I applied the first coat of PP, thinned about 10% with brush thinner. It seemed to separate like a golf ball surface. Sort of like it was being rejected by the teak. However, it is a two part varnish and specifically says it is compatible over top of other two part varnishes, which is what Bristol Finish is.
I decided to see whether additional coats would smooth out the surface. I did not thin the second coat, thinking it may fill the holes. Mistake. While it says it can be applied without thinner, I ended up with millions of tiny air bubbles.
Had to sand it all off.
I thought, however, with a good compatible base now, the PP would adhere without the golf ball surfacing. Nope. Exact same result. I decided to press forward and see if more coats would fill and they are slowly reducing these pock marks. I have three coats on now and I'm afraid it is going to take a dozen to smooth it out.
My plan was also to wet sand the final coat and buff. Now I've read somewhere that PP may not take well to buffing.
This is turning into a fiasco. I may be stripping it all down again. (btw, there is no know chemical stripper that will attack this finish. It must be sanded)
I really liked Bristol Finish and hope someone starts making it again!!!! While they both give off some serious VOCs, the PP is practically chemical warfare. Says it is the hardest finish on the planet and I believe it. Could be because it kills anyone within 5 feet of it.
chef2sail and jimgo like this.
Jeanneau 54DS
post #3 of 18 Old 01-24-2013
redline's Avatar
Re: Perfection Plus
I'm even gladder my cockpit table is white Starboard. The seats and floor are teak, and while I haven't entirely embraced the "teak is grey, brass is green" school of boat maintenance, I have learned to love bare wood underfoot, not to mention wishing I could recover all those hours previously spent scraping, sanding, and coating.
I can see that a table needs some surface protection; all I can think of is that Star Trek movie where Scotty whips up the formulae for Transparent Aluminum. Now where's that DVD...?
oysterman23 likes this.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #4 of 18 Old 01-24-2013
Re: Perfection Plus
While it seems that you've already started the project, I found that helpful interlux info is available over on Yachtpaintforum.com
lancelot9898 is offline
post #5 of 18 Old 02-27-2013 Thread Starter
Re: Perfection Plus
Felt compelled to clear the name of Perfection Plus. As I said above, it wasn't coming out very well.
Of all coincidences, I was emailing her prior owner and mentioned the work on the table. He drops a bomb that I wasn't asking, nor expecting. While everything else was Bristol Finish, he had done the cockpit table in real varnish!!!!!!
Holy smokes. No wonder it was a disaster. The solvents in the two part PP just dissolve the thin layer of varnish I thought I was leaving as a base. Of all ironies, I had actually top coated the varnish with Bristol Finish along the way and that worked fine. Still wish they made the stuff.
Well, back to the beginning. I can't believe it. All to be sanded back to bare and done from scratch. I really can't stand the thought of another couple of weeks of those two part potting vapors, so I'm doing what I should have done originally. Epifanes clear varnish.
chef2sail likes this.
Jeanneau 54DS
post #6 of 18 Old 02-27-2013
Re: Perfection Plus
Thanks for the follow-up, Minnie.. One of the things I don't really like about some of these new finishes is their 'clarity'.. I like/want the golden hues of a good varnish, and these 'clear' finishes make redoing a damaged area difficult if you've lost the original 'colour' finish..
Faster is online now
post #7 of 18 Old 02-27-2013
Re: Perfection Plus
I ran into a similar problem re-finishing a table with one part poly urethane varnish. The only thing I could think of was that someone along the line used a silicone based polish on it. Finally had to take it all the way down to bare wood and scrub with acetone, just about went through the veneer. It finally finished just fine.
Paul T
dabnis is offline
post #8 of 18 Old 03-02-2013 Thread Starter
Re: Perfection Plus
I will tell you what, I only put on 3 or 4 coats of the Perfection Plus and I'm trying to get down to bare wood. It is incredibly hard to get off. If one could get it to come out right, it would be good for nuclear protection.
It did get me thinking. If you ever needed to repair it, the removal would be (is) tortuous. I'm glad to be returning to good old fashioned varnish.
Jeanneau 54DS
post #9 of 18 Old 03-02-2013 Thread Starter
Re: Perfection Plus
I'm on break again and calling it a night. One piece, approx 18" x 40" took Twelve 50 grit sanding pads on a random orbital.
Jeanneau 54DS
post #10 of 18 Old 04-22-2013 Thread Starter
Re: Perfection Plus
Finally done. After sanding to dull finish and applying Bristol Finish only find they aren't making it any more. To re-sanding and applying Perfection Plus, only to learn that the original owner actually used real varnish on the table, while they used Bristol Finish on everything else. To stripping it fully down to bare wood and applying 10 coats of clear Epifanes varnish.
We didn't really photo document, but here are some shots:
This was the third full strip in progress:
Attachment 13949
Finally stripped to bare wood. That was a lot of work.
After 6 coats of clear varnish
After 8 coats, you can see the picture hanging on the wall in the reflection
After 10 coats, you could see yourself in it. Well, you might not all recognize me on the street.
Finished and reinstalled !!
Jeanneau 54DS
Buffing Perfection cas8100 Gear & Maintenance 10 01-06-2017 09:16 PM
Perfection lauderdale blue eMKay Gear & Maintenance 0 04-12-2010 12:10 PM
Where to buy Interlux Perfection? superiorvoyager Gear & Maintenance 24 03-01-2010 04:03 PM
My Perfection is no longer FUBAR tommays Gear & Maintenance 3 05-13-2009 03:04 PM
Perfection does really shine tommays Gear & Maintenance 4 02-25-2009 09:36 AM
