Battery Cable Crimper - Page 3 - SailNet Community
 4Likes
post #21 of 22 Old 01-01-2013
captrice
Buy a small propane torch and some large solder strip your insulation back 1 to 2 inches from your connector place in a vise or vice grips heat the connector apply the solder until it fills the connector. You will not get a better connection.
captrice is offline
post #22 of 22 Old 01-01-2013
Re: Battery Cable Crimper
I soldered mine just like above. Remember to slide your heat shrink on the wire before you solder it in case it will not fit over your connector. Just melt the solder into the connector until is full and shove the wire into it. Wait about 30 seconds or so before you release it. I use a steel bench vise to hold the connector vertical so you can fill it up.
Drumbeater is offline
Battery cable size?? micheck General Discussion (sailing related) 9 06-13-2011 06:54 PM
Battery cable sizing micheck General Discussion (sailing related) 0 06-10-2011 04:50 PM
Windless cable size, cable manufacture and battery type? SanDiegoChip Gear & Maintenance 25 02-19-2010 10:44 AM
Battery Cable Help Snboard976 Gear & Maintenance 12 05-17-2009 08:00 PM
Battery Cable Sizing labatt Gear & Maintenance 11 02-19-2009 11:15 PM
