what glue for attaching foam insulation to the cabin interior? - Page 2 - SailNet Community
post #11 of 14 Old 01-02-2013
geehaw's Avatar
Re: what glue for attaching foam insulation to the cabin interior?
I think you will find that the spray adhesives eats the insulation. Have been thinking about this myself. I was thinking water-base contact cement or just foam board adhesive. I don't see anything holding that would leave it easily removable. I was thinking of using the vinyl flooring that looks wood flooring. But it is so heavy I doubt any glue would hold it vertical or overhead on foam board. And it might not lay flat on all the contours. Well I hope someone pipes in with a tried solution. Kb3pwc solution sounds the best so far.
geehaw is offline
post #12 of 14 Old 01-02-2013 Thread Starter
I just ordered some of that non-woven carpeting which fits the contours (ie "monkey fur"), it is essentially the same as what was there before. It is not for the headliner, only for the sides of the v-berth laying on the hull. The stuff which was there had gotten mildewed over the years and was a little nasty, so I ripped it out and now want to insulate since I've got it out already. I even have the old carpeting to act as a template for the new stuff.
I had considered a nice cedar lining for the v berth but frankly, it would cost double what the carpeting costs and take 5 times longer to do. It's cold out, and I have other jobs which need doing so I don't really have the time. Especially since I don't live aboard, and it's just an old Hunter 25 nothing special. I am not too concerned about mildew anymore, since I did a refit last year and now don't have a drop of water intrusion anywhere on the boat even in heavy rain.
I don't know about the spray adhesive because there will def be gaps between the hull and the insulation, and I am concerned that moisture will condense in these gaps. Plus there will be a very imperfect bond anyway. The surface of the underlying fiberglass is very rough and still has some hairs from the original carpet stuck to it in a few places. Ideally I would sand it smoother and remove all surface imperfections for gluing, but I feel that this is a bit overboard and unnecessary in this particular case. So I figured some sort of a gap filling sealant/adhesive would be best. However maybe I will just go with the 3m if that will be adequate... marine caulking is dam expensive and I would need ALOT of it!
peterchech is offline
post #13 of 14 Old 01-02-2013
blt2ski's Avatar
Headlining Replacement
That link has the how I did the aft cabin, plus a link at the end to the head redo. I also did the main saloon and V-berth area in a similar manner. ust not as many pics of those area's.
I second the 3M spray contact cement. I found the 88? worked as well as the 9x version, but did not smell as bad. The blue can, ie 77 was for the most part useless and a waste of $$$.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #14 of 14 Old 01-02-2013
IIRC the 3M #77 is for graphic arts use, not a structural adhesive. They make different grades of adhesive for different purposes, i.e. if you want to glue an overhead headliner to the underside of a car roof, where it gets quite hot baking in the sun, you need to use the "headliner" adhesive which is designed to resist the heat. Other special grades do other special tricks, like bond to "unglueable" plastics including polyethlene.
They're not all the same.
And 3M has some of the best toll-free customer support in the world, call the number on any product and you'll get real answers, not just someone reading a book.
hellosailor is offline
Foam for interior cushions?? Adele-H General Discussion (sailing related) 33 01-06-2013 09:09 AM
insulation - glue or velcro!? stantale Gear & Maintenance 5 01-16-2011 07:48 PM
Which foam for interior cushions? jephotog Gear & Maintenance 7 08-26-2009 09:35 PM
attaching wires to cabin roof LookingForCruiser Gear & Maintenance 7 06-15-2009 12:41 AM
Sound Insulation Foam Sue & Larry Gear and Maintenance Articles 0 01-31-2002 08:00 PM
