One-way valve in bilge pump outlet line? - SailNet Community
post #1 of 2 Old 01-03-2013 Thread Starter
Last weekend I had a problem where (I was on the boat at the time, thankfully) the bilge pump did not stop running, but did not appear to be pumping any water out at the stern. The problem appeared to be that the one-way valve in the line from bilge pump to stern, had stuck.
Question is, do I even need this valve? What does it protect me from?
MarkSF is offline
post #2 of 2 Old 01-03-2013
Maine Sail's Avatar
Re: One-way valve in bilge pump outlet line?
Mark,
This thread should help explain it all. Your scenario is exactly what I described in that thread..
Bilge Check Valve / Non-Return Valve
______
-Maine Sail / CS-36T
Maine Sail is offline
Bilge pump non return valve. H and E Gear & Maintenance 61 08-11-2015 08:12 PM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 08:26 PM
Check alve - in outlet of the bilge pump velero Gear & Maintenance 11 04-03-2010 09:06 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 12:36 PM
Bilge pump dump below water line boydgatlin Sailboat Design and Construction 5 07-06-2009 12:20 PM
