Paint gelcoat - Page 2 - SailNet Community
 2Likes
post #11 of 28 Old 01-04-2013
Re: Paint gelcoat
Epoxy alone, even if coloured, won't hold up against UV. You have to paint over it, otherwise it will yellow in the sun.
MarkSF is offline
post #12 of 28 Old 01-04-2013
Re: Paint gelcoat
Originally Posted by davidpm View Post
I was thinking of using maas or system3 or west with 207 hardener all I believe have no blush.
I understand there are 'low blush' .. are there really 'no blush' epoxies?
Faster is online now
post #13 of 28 Old 01-04-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Paint gelcoat
Yes, trying to apply gel w/a roller or brush *would* be a PITA and look like poop. Understood that gel gets it's "face" from the master mould. I saw a vid w/some guy spraying gel; some as the master plug w/some sorta exrta hard molding gel, and some "regular" during molding process...so it's possible. Doesn't gel have the UV inhibitors??
deltaten is offline
post #14 of 28 Old 01-04-2013
Re: Paint gelcoat
Gelcoat does have UV inhibitors added. There are some that can and do respray gelcoat. However, that will either be prohibitively expensive to get a pro to do an entire deck, or very likely to be a DIY disaster.
Jeanneau 54DS
Minnewaska is offline
post #15 of 28 Old 01-04-2013
chucklesR's Avatar
Re: Paint gelcoat
Just out of curiousity, I'm assuming you mean the shiny parts - the non-skid areas would/will be coated with something else.
That being the case, look at the soft deck or cool deck EPA foam stick ons, they work good and feel great.
chucklesR is offline
post #16 of 28 Old 01-04-2013
deltaten's Avatar
Re: Paint gelcoat
Makes me wonder about other, industrial epoxies as deck coatings?? There's some used on guns that are seriously effective at repelling scratches and common wear. These started out as specific industrial equipment finishes; so I'd think that they'd have *some* application??
deltaten is offline
post #17 of 28 Old 01-04-2013
tommays's Avatar
Re: Paint gelcoat
The BIG BIG BIG BIG issue and it is a BIG issue is taping pulling and re-taping between coats
Its a large amount of work when doing the topsides and you can reach everything its a whole another can of worms when you do the final Awlgrip coats as you have a fairly short window to pull the tape or you will lift of tear the edges
The 545 primer is really friendly to work with the topcoat is a science project of matching temperature and humidity when your working outdoors AND bugs like it a LOT
Your going to go from this
To this which this and absurd amount of 545 primer at which point you will be thinking painting is pretty easy
Once you hit this point its humble pie time as suddenly you now have tiny UNFORGIVING WINDOWS and a paint that gets angry because it 3 degrees colder that it was the day before or you should have put in one more ounce of reducer
I will stick with interdeck or kiwigrip as there durable enough and you can really screwup and get a good result
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #18 of 28 Old 01-05-2013
Re: Paint gelcoat
I ask the question again...with non-skid making up MOST of a deck (at least on my Edel) why not just do the whole deck in non-skid? On my boat it would be impossible to sun yourself in your Speedo or less without having most of your body lying on non-skid. What is the practical purpose of the smooth lines between the non-skid other than they stay cleaner?
i_amcdn is offline
post #19 of 28 Old 01-05-2013 Thread Starter
davidpm's Avatar
Re: Paint gelcoat
Originally Posted by Minnewaska View Post
Is that technically true? Awlgrip is a two part linear polyester urethane, but I'm not sure it qualifies as epoxy?
I believe you are correct.
I just meant that it is compatible with epoxy. IE you can awlgrip over epoxy.
davidpm is offline
post #20 of 28 Old 01-05-2013 Thread Starter
davidpm's Avatar
Re: Paint gelcoat
I've seen it done. I personally don't like the look especially on vertical surfaces of the cabin.
davidpm is offline
Why paint instead of gelcoat? aaronwindward Gear & Maintenance 110 07-19-2014 04:28 PM
Removing paint from Gelcoat lrak Gear & Maintenance 17 04-15-2014 03:11 PM
Gelcoat or Topsides paint? leogallant Gear & Maintenance 1 09-14-2012 09:41 AM
Is this paint or gelcoat? bamabratsche Gear & Maintenance 8 02-20-2012 05:37 PM
Gelcoat? Paint? dmcleaner General Discussion (sailing related) 8 06-15-2010 11:24 AM
