Paint gelcoat - Page 3 - SailNet Community
 2Likes
post #21 of 28 Old 01-05-2013 Thread Starter
davidpm's Avatar
Re: Paint gelcoat
[QUOTE=tommays;970969]The BIG BIG BIG BIG issue and it is a BIG issue is taping pulling and re-taping between coats /QUOTE]
In your pictures the posts hold up the tarp seem to be just there. What is hold them up?
davidpm is offline
post #22 of 28 Old 01-05-2013 Thread Starter
davidpm's Avatar
Re: Paint gelcoat
Originally Posted by poopdeckpappy View Post
Sand surface
Awlgrip high build primer
Sand (repeat above if needed )
Awlfair
Sand ( repeat above if needed )
Awlgrip epoxy primer
Sand
Sand
Top coat ( min 2 coats )
For the non-skid use fine silica sand ( by the sh*t load ) bury the first layer of top coat with sand, 24hrs later vac sand and apply top coat until the desired feel is achived.
It will look awsome, but ya got to use sand liberally
So you don't think is is necessary to wash the surface with epoxy to fix it.
You must figure the hi-build primer is good enough?
Are you assuming I'm sanding all the gelcoat off or just cleaning it up.
davidpm is offline
post #23 of 28 Old 01-06-2013
poopdeckpappy's Avatar
Re: Paint gelcoat
No I don't think it's needed, the high build is a really good foundation, once you've done the fairing/sanding and sanded first coat of epoxy primer, look close for imperfections and spot those with a good epoxy fill,( should be minimal if any ) then do your 2nd coat of primer and sand that, at this point your deck should be/will be smooth as a baby's butt.
I assuming you are sanding just enough to prep a good bond for your first coat of HB, if you do sand threw the GC, it's no biggie, just avoid sanding into the glass.
To quote some goofball on TV, " you're gonna like what you see "
davidpm likes this.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #24 of 28 Old 01-07-2013 Thread Starter
davidpm's Avatar
Re: Paint gelcoat
if you do sand threw the GC, it's no biggie, just avoid sanding into the glass."
If I sand through the gel coat aren't I by definition into the glass?
So I'm thinking to just not grind any more glass than necessary,yes?
Or is their another layer between the gel coat and the glass?
davidpm is offline
post #25 of 28 Old 01-07-2013
Re: Paint gelcoat
Not really, when the GC looks semi translucent you know you've gone far enough and you may not even need to go that far
you shouldn't be grinding any glass, even when grinding down the non-skid you should try not to go into the glass, you should be able to grind the nibs ( which is mostly resin ) down before you hit any glass material
No,not really
1974 Ranger 33
post #26 of 28 Old 01-07-2013
Re: Paint gelcoat
Have you used high build before ?, it will undo all your sins made with the sanding or grinding
1974 Ranger 33
post #27 of 28 Old 01-15-2013 Thread Starter
davidpm's Avatar
Re: Paint gelcoat
Anyone make a good high build besides awlgrip. I have a couple of dinghys I'm working on.
Not needed but I would like to see how it behaves.
davidpm is offline
post #28 of 28 Old 01-16-2013
Re: Paint gelcoat
Pro Line is another brand
davidpm likes this.
1974 Ranger 33
Why paint instead of gelcoat? aaronwindward Gear & Maintenance 110 07-19-2014 04:28 PM
Removing paint from Gelcoat lrak Gear & Maintenance 17 04-15-2014 03:11 PM
Gelcoat or Topsides paint? leogallant Gear & Maintenance 1 09-14-2012 09:41 AM
Is this paint or gelcoat? bamabratsche Gear & Maintenance 8 02-20-2012 05:37 PM
Gelcoat? Paint? dmcleaner General Discussion (sailing related) 8 06-15-2010 11:24 AM
