42 Passage water tank replacement - SailNet Community
post #1 of 6 Old 01-05-2013 Thread Starter
theartfuldodger's Avatar
Send a message via Skype™ to theartfuldodger
Has anyone ever changed or worked on the main water tank of this vessel as I'm going to have to repair mine and any pointers would be greatly helpful
Brake Free
Lake Ontario
42 CC Passage
theartfuldodger is offline
post #2 of 6 Old 11-17-2013
Re: 42 Passage water tank replacement
Did you end up replacing this? If so any information would be helpful
Puestadelsol is offline
post #3 of 6 Old 11-17-2013
I had these guys fabricate a brand new custom tank for me last year. Very pleased with quality, service and price. You usually have to pick two.
Triple 'M' Plastics, Custom Plastic Fabrication since 1972 - Home
Jeanneau 54DS
Minnewaska is offline
post #4 of 6 Old 11-17-2013
I am also looking for information on how to get to this tank
post #5 of 6 Old 11-18-2013
kd3pc's Avatar
there are two tanks actually, one to port under the settee with the aft end just below the water heater and the aft end of the settee...you will likely need to remove some cabinetry/seat frames and flooring to get access...of course pull up and set aside the water heater. there she be. now is also the time to replace hoses, valves and filters so plan ahead.
the other is under the vberth in the fore peak, and it, too, will require some gymnastics to get it out. Most likely will require cutting to get it out, unless you have two or three sets of hands and pad the entire center line of the boat....then you still may need those hands to actually get it out the companionway. Measure and test with a carboard template to make sure you have clearance under the bimini/dodger and the framing that goes with it. It is very awkward to manhandle.
I would likely go with multiple smaller tanks for ease of replacement....and for sure out of plastic, triple M is great. I made a "manifold" for filling as well as distribution, such that any tank or any source can be shut off, or not used. Labeling is critical for future owners and a drawing with part numbers, sizes and shapes in the ships log.
Best of luck. It is a DIY job, if you are handy, but costly (due to the labor and hands needed) if you get the yard to do it.
kd3pc is online now
The Following User Says Thank You to kd3pc For This Useful Post:
Puestadelsol (11-18-2013)
post #6 of 6 Old 11-18-2013
Thanks... I was afraid it would be that much work. Maybe a next winter job. Has anyone replaced the reefing system within the boom? Not sure how to get it apart - looks like pop rivets
Atlantic Marine Hot Water Tank and Fresh Water Winterization Dcneuro Gear & Maintenance 5 12-17-2012 11:03 AM
CS27 Holding & Water Tank Replacement cghubbell CS Yachts 9 09-29-2011 07:50 AM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Water tank replacement options Valiente Gear & Maintenance 12 10-08-2007 10:11 PM
Refrigeration -Using the water tank as a cooling water source HenryRusty Gear & Maintenance 7 03-29-2007 12:14 AM
