Like Tree10Likes
  #11
Old 01-06-2013
Jgbrown is on a distinguished road
Re: best way to mount Aluminium to steel underwater
Hmm. What about using a Marelon thru-hull as a spacer?
You could use better lights, such as the Ocean-LED HD series, they have bronze bodies, and stick through enough that you can attach a bonding wire to the backside, this seems to be OK for FG boats, I don't know about steel though, if grouding bronze to the regular zinc would be sufficient.
*Note: We are a registered dealer/installer for Ocean-LED, but I think anything similarly well built should due the trick.
I do agree they are a bit silly, though could be neat for night diving/fishing I've sometimes thought.
  #12
Old 01-06-2013
mitiempo's Avatar
To attach any other metal (aluminum or bronze) to the hull of a steel boat is asking for trouble. Except for the propeller and shaft keep it to steel only. A spacer wouldn't help much as the salt water connects the light housing and the hull.
The West Marine lights you linked to are NOT aluminum though - they are, as already mentioned, polycarbonate so there would not be any issues with those.
Jgbrown likes this.
Brian
  #13
Old 01-06-2013
Alex W's Avatar
Alex W is on a distinguished road
These seem like a great way to add some underwater drag. Do you really want that? I'm not against needless underwater bling (I don't want it on my boat, but would never suggest that someone wouldn't want it on their's), but needless underwater bling that adds through hulls and drag seems like a pretty bad idea. It's also likely to hurt resale...
1986 Pearson 28-2 "Elena"
frequent crew/prior owner on Catalina 25 "Lutra"
Shilshole Marina, Seattle, Puget Sound, WA, USA
  #14
Old 01-07-2013
xymotic is on a distinguished road
I have one in my hand and it is most certainly milled billet aluminium.
However, it's also not "in" the hull, it's surface mounted. So I'm really only concerned about standing it off of the hull, the light comes with nylon spacer to keep the Stainless screw from contacting the Alum body.
  #15
Old 01-07-2013
At this point I'm unsure whether I will put them on the sides or just at the transom.
But my boat is a 40,000 pund monster with a 20" wide keel and a whole bunch of welded plate that was never faired. Not really sure drag is my top concern.
  #16
Old 01-07-2013
Originally Posted by noelex77 View Post
There is no danger to the hull. The problem is the light is nice anode for the hull. If the aluminium light housing dissolves, which it will do sooner or later, you are left with a hole in hull underwater
Thanks, That is a concern indeed.
As for the actual hole for the wire, it can be pretty small, less 1/8" or so.
What would be the best way to seal it? Inject epoxy? Or am I over-thinking that as well and just use 5200?
  #17
Old 01-07-2013
boatpoker's Avatar
boatpoker is on a distinguished road
noelx77 is correct, done improperly this could sink your boat.
"electrolysis" is not the issue. Electrolysis is the chemical change in a solution or electrolyte due to the passage of electric current.
The potential problem here is "galvanic" corrosion and mixing steel, aluminum and DC current under water could cost you big time if not done properly. I strongly advise you to consult an ABYC certified electrician before proceeding.
Dirt People Scare me
  #18
Old 01-10-2013
I may rethink this and find an all plastic version instead. Seems safer.
But same question: If I drill & tap the hull, what's the best way to seal the thread and prevent galling? Something like permatex thread sealant, Tef Gel (water tight??) or 5200?
  #19
Old 01-11-2013
mitiempo's Avatar
I would use 3M 4200 or Sika 291
Brian
  #20
Old 01-11-2013
Maine Sail's Avatar
Xymotic,
PLEASE, please, please before you do anything below water to your metal hull buy and read Everett Collier's book
The Boatowner's Guide to Corrosion: Everett Collier: 9780071550192: Amazon.com: Books The Boatowner's Guide to Corrosion: Everett Collier: 9780071550192: Amazon.com: Books
Read it three or four times so the science of if fully absorbs..
Ed Sherman, the education director for the ABYC, recently wrote about a LARGE and EXPENSIVE motor yacht that sank due to its David Hasselhoff/Knight Rider under water lights, or as they are often affectionately refereed to as "look at me lights" .. Glug, glug, glug all because of corrosion.
This was the hole left in the vessel when the fixture completely eroded away due to corrosion. This boat sank due to corrosion of an under water light.
Image Courtesy Ed Sherman:
Not saying not to do this, just saying that you should FULLY EDUCATE yourself BEFORE doing this...
When you own a metal boat it is far more important for YOU to learn about corrosion than for others on the net to try and "tell" you about it. Please start with Everett's book....
xymotic and Lou452 like this.
______
-Maine Sail / CS-36T
You may post attachments
You may edit your posts
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
Aluminium/steel hull slawomirjc Boat Buyers & Sellers Forum 2 09-03-2010 01:13 PM
Radar - Stern Mount or Mast Mount night0wl Gear & Maintenance 34 03-19-2009 07:00 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
aluminium prep oz_hole Gear & Maintenance 3 01-22-2003 02:58 PM
SEO by vBSEO 3.6.1
