best way to mount Aluminium to steel underwater - Page 3 - SailNet Community
 10Likes
post #21 of 25 Old 01-12-2013 Thread Starter
Re: best way to mount Aluminium to steel underwater
Thanks, great advice and looks like a good book
xymotic is offline
post #22 of 25 Old 01-13-2013
I'm a bit curious, what is the purpose of the underwater lights for you? One thing I have noticed with most that the customers are usually underwhelmed with what they see in the water. They are more decorative than anything, sort of like the under car lights, while most people seem to expect them to act as big spotlights to see lots of fish etc, or functional that they could see the bottom.
Especially if there's any pollution in the water, or boats with swim grids on the back, it doesn't look anything like the photos in the ads.
The latest ones we're using are these: OceanLED - Colours TH HD
they are a lot brighter, bronze and use a much smaller hole, with a synthetic spacer for metal hulls, power hungry though.
What about surface mounting them? If it's just for goofing around at anchor, you could put a magnet on a nice waterproof bright light and stick it over the side and have a useful tool in the meantime.
Faster likes this.
Jgbrown is offline
post #23 of 25 Old 01-14-2013
Old enough to know better
This sounds like a good idea, as the synthetic spacer would have to be very thick to protect it as salt water will act as the conductor. The only problem is that most of these lights need the water for cooling, so it would not be much use out of the water. They can be useful to attract fish, and I imagine lots of insects. In most waters it is too cloudy to see anything, so useless. Might help for diving to clear a prop. With the exception to attracting fish, these always seemed like the under car lights, and coffee can mufflers on cars, all show and nothing for go.
miatapaul is offline
post #24 of 25 Old 01-15-2013 Thread Starter
The ones I'm contemplating are blue, LED, and just fo augment other lights I'm putting on deck to make it kinda pretty at night. Or stupid/tacky depending on how you look at it I guess.
xymotic is offline
post #25 of 25 Old 01-15-2013
I like the look of a sailboat with small decorative white lights under each spreader. They have a little bit of that "look at me" factor, but they serve a great purpose in identifying your boat among a hundred anchor lights at night. I've also seen a light installed under the boom to create a sort of night light, while walking through the cockpit. These seem classier to me than blue stinkpotter hull lights.
I have neither, but I do have the underwater lights installed by the prior owner. They aren't colored for decoration, they are underwater flood lights, which I've used on other boats in the Caribbean. Its like having your own aquarium at night. But up here, they are utterly useless and worry me.
Jeanneau 54DS
Minnewaska is offline
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
Radar - Stern Mount or Mast Mount night0wl Gear & Maintenance 34 03-19-2009 07:00 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
aluminium prep oz_hole Gear & Maintenance 3 01-22-2003 02:58 PM
