Lewmar Winch bolt mounting pattern question - SailNet Community
post #1 of 3 Old 01-07-2013 Thread Starter
rhr1956's Avatar
I want to replace a Lewmar #7 winch with a Lewmar #8. Does anyone know if the bolt pattern for mounting is the same for both winches or different?
rhr1956 is offline
post #2 of 3 Old 01-09-2013
No more curry buffets
Ritchard's Avatar
Re: Lewmar Winch bolt mounting pattern question
According to the first chart on this page:
http://www.pyacht.com/lewmar-winch-specs.htm
The drum and base of the 7 and 8 are the same. I'd bet as a result the bolt pattern is the same as well.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #3 of 3 Old 01-12-2013
It may depend on the relative ages of the two. I replaced alloy Lewmar
ST 30's with what appeared to be identical Lewmar ST 30 bronze/chrome.
The diameter was identical, so the new ones fit on the mounting pad OK.
But the holes were slightly different. PITA.
arvicola-amphibius is offline
Lewmar winch Foxsea Introduce Yourself 4 06-06-2011 12:19 AM
mounting a winch jimmd Gear & Maintenance 3 11-04-2009 09:22 PM
mounting a winch on the mast soulesailor Gear & Maintenance 15 06-23-2008 11:25 AM
O/I 28 Eng. mounting bolt failure CowboyPhD Morgan 2 12-03-2006 09:42 AM
