Like Tree5Likes
  #11
Old 01-09-2013
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: problem diagnosis needed, no speed, smoke, low rpms
Originally Posted by jrd22 View Post
I would guess the max prop is stuck in the feathered position. Doesn't take much growth to keep the blades from rotating. My brothers Auto prop was stuck from non-use, had the same symptoms you are describing.
Wouldn't that behave more like the trans was in neutral? I don't understand how a closed prop could prevent the engine from revving up or cause black smoke.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #12
Old 01-09-2013
Jon it's a feathering, not folding prop... it could be stuck in a VERY coarse pitch condition, if not actually fully 'feathered'...
SloopJonB likes this.
  #13
Old 01-09-2013
thegreenflash is on a distinguished road
I thought about the prop being stuck in the wrong position, I will check tomorrow.
  #14
Old 01-09-2013
gbtillman is on a distinguished road
If everything turns freely, check the turbocharger. When they fail the intake air can be restricted and I'm not sure for a Yanmar turbo but some are lubricated with the engine oil that can leak into the intake causing smoke and oil in the exhaust. I have seen a Cat diesel run away from an oil leak and overspeed even after the fuel was shut off.
If the impeller has failed you can also have pieces of it going through the intake valves and into the cylinders.
  #15
Old 01-09-2013
The engine runs and revs fine and clean in neutral.. that coupled with heavy loads and no 'drive' points to the prop, I'd say...
  #16
Old 01-09-2013
LessTacksing is on a distinguished road
Send a message via Skype™ to LessTacksing
These responses are what I find to be the best of Sailnet...
David
David
  #17
Old 01-09-2013
lancelot9898 is on a distinguished road
You know if it is in fact the prop being stuck in the feathering position, I'ld like to hear an explaination from max prop. ie...lack of proper grease, broken gear
I don't see how a barnicle could be strong enough to keep it from rotating, but you never know.
  #18
Old 01-09-2013
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
The boat has had 5 months on a mooring in St Augustine. I reckon those barnacles may be oysters. I was there a month and my prop needed doing.
chef2sail likes this.
Sea Life
Notes on a Circumnavigation:
I write with an iPad and its spell checker changes some words. Beware.
  #19
Old 01-09-2013
Yamsailor's Avatar
Yamsailor
Yamsailor is on a distinguished road
Is your wet exhaust discharging normally? if not, then check the elbow on your exhaust manifold. I had the exact same problem and realized the wet exhaust was exiting the elbow because it had a hole in it. The water drained to the bilge instead of out the exhaust pipe.
Overtime the interaction of seawater and exhaust gases cause minerals and carbon to precipitate on the walls of the elbow. Eventually the elbow clogs (like a heart attack) causing the exhaust pressure to build up and blow a hole in the manifold. You won't get an overheat alarm because the raw water is doing its job cooling the engine. The reason you have low rpms may be due to a pressure imbalance between the engine and the manifold. Replacing the elbow will eliminate the problem if this is indeed the problem.
Good luck.
There isn't a device on this world that can measure the indifference I have for that statement.
  #20
Old 01-11-2013
Problem solved....It was due to growth, much more barnacles on the prop than I first thought, also the blades were not moving freely at all. The barnacles on the "hub" were preventing the prop from feathering correctly. 10 minutes in a wetsuit and it was solved, tachs up fine now with plenty of power. Thanks for the replies.
Steve
You may post attachments
You may edit your posts
Problem starting Yanmar 2QM20H and white smoke when running epp Diesel Engine Forum 10 07-30-2010 01:20 AM
Another Exhaust Smoke Diagnosis DrB Diesel Engine Forum 1 07-06-2010 09:46 AM
The Color of Smoke and What the problem could be CarelessNavigator Diesel Engine Forum 0 04-05-2010 02:12 PM
White Smoke from Older Diesel at Higher RPMs kcoffey Gear & Maintenance 3 06-24-2004 03:23 PM
Yanmar (3GM 20hp) Blue Smoke Problem animaashi Gear & Maintenance 3 11-05-2001 06:18 PM
SEO by vBSEO 3.6.1
