problem diagnosis needed, no speed, smoke, low rpms - Page 3 - SailNet Community
 5Likes
post #21 of 26 Old 01-11-2013
Re: problem diagnosis needed, no speed, smoke, low rpms
Originally Posted by thegreenflash View Post
Problem solved....It was due to growth, much more barnacles on the prop than I first thought, also the blades were not moving freely at all. The barnacles on the "hub" were preventing the prop from feathering correctly. 10 minutes in a wetsuit and it was solved, tachs up fine now with plenty of power. Thanks for the replies.
Steve
all together now.... HIP HIP.. 3 cheers for jrd22!!
Faster is online now
post #22 of 26 Old 01-11-2013
Senior Moment Member
SloopJonB's Avatar
This place is freakin' amazing.
SloopJonB is offline
post #23 of 26 Old 01-11-2013
chef2sail's Avatar
Feeling a little overlooked by Ron here
Posted in thread #3
You problem is proababaly shaft related, whether its growth or cutlass.
I would venture to say if all was fine before it is growth. Its amazing how a few barnacles can retard the boat speed. Thats the simple solution. More complicated could be shaft misalignment, a bad cutless bearing, or the coupling especially since you said you felt vibration, but again growth can cause that also. Think simple first. Chef2sail
Its ok that jrd22 is a good fellow
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #24 of 26 Old 01-11-2013
Sorry, Dave... but it was John that nailed the 'stuck in the feathered position'... OK... one cheer for you too!!
chef2sail likes this.
post #25 of 26 Old 01-11-2013
chef2sail's Avatar
.....Yes because of the Barnacles...but I am jiggy with sharing with John. I would love to me him when I get out that way as he seems like a great guy. He has an awesome boat it looks like too.
Dave
Parkville, Maryland
Our blog-
post #26 of 26 Old 01-12-2013
Yamsailor
Yamsailor's Avatar
All I can say is..I am glad I was wrong!
There isn't a device on this world that can measure the indifference I have for that statement.
Yamsailor is offline
Problem starting Yanmar 2QM20H and white smoke when running epp Diesel 10 07-30-2010 02:20 AM
Another Exhaust Smoke Diagnosis DrB Diesel 1 07-06-2010 10:46 AM
The Color of Smoke and What the problem could be CarelessNavigator Diesel 0 04-05-2010 03:12 PM
White Smoke from Older Diesel at Higher RPMs kcoffey Gear & Maintenance 3 06-24-2004 04:23 PM
Yanmar (3GM 20hp) Blue Smoke Problem animaashi Gear & Maintenance 3 11-05-2001 07:18 PM
