What's Wrong With This Picture?? - Page 2 - SailNet Community
 3Likes
post #11 of 30 Old 01-09-2013
Coquina's Avatar
Re: What's Wrong With This Picture??
Also if you have a real old boat with a TRIPLE pole breaker that interrupts the green wire, please do jumper around that one!
Coquina is offline
post #12 of 30 Old 01-09-2013
Brewgyver's Avatar
BTW, and unrelated to your pop quiz, the indicators are either incandescent or neon, not LEDs, and just need a few turns of white electrical tape on the black wires connected to neutral.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #13 of 30 Old 01-09-2013
Freedom 39
FarCry's Avatar
Originally Posted by FarCry View Post
From this photo it's hard to decipher where the incoming feed is etc. It does look like one of the breakers may be jumpered on the right, I believe.
Above was post #3. I guess I need to supply arrows next time.
My previous reply was composed before I saw MS's reply. All good info and great to work the mind and assume NOTHING existing is correct. Thanks Maine Sail.
FarCry is offline
post #14 of 30 Old 01-09-2013
Coquina's Avatar
When I was in the business I would see stuff like that and think and $$$$. I always figured everything else was even worse.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #15 of 30 Old 01-09-2013
Chastened
Ajax_MD's Avatar
Why couldn't they be LED's? I have a Blue Sea Systems panel that came equipped with them. They definitely are LED's, also confirmed by the spec sheet and installation instructions.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #16 of 30 Old 01-09-2013
Coquina's Avatar
They don't look like LEDs to me. They look like old neon lights.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #17 of 30 Old 01-09-2013
bljones's Avatar
Red is also an improper color to be used on this particular panel. Red wire denotes 12V DC + or one leg of a 240V AC system. This is a 120V system and as such only BLACK/HOT, WHITE/NEUTRAL and GREEN/SAFETY GROUND are to be used not red. While not the main problem it is one of the many smaller "issues" ....
Main, the red hots appear to be only used breaker to breaker, not on a run. Was that ever accepted standard in the past, because I've seen it before.
It's 5 o'clock somewhere:
bljones is offline
post #18 of 30 Old 01-09-2013 Thread Starter
Maine Sail's Avatar
Those are neon indeed because it is an older boat and I did not replace them with LED as all were still working. You also can't be fooled by the "look" of the indicator light. The manufacturers of those indicators offers that same indicator light style in LED, neon and incandescent. Most every new AC/DC panel ships with LED indicators so I am just used to saying "LED".. I also generally replace neons with LED when dong a panel rebuild and some neons are shot...
The neutrals were tied into a white/neutral wire running back to the neutral bus and the reverse polarity got a green pig tail where it heads off to the grounding bus....
OPossumTX likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #19 of 30 Old 01-09-2013 Thread Starter
Maine Sail's Avatar
No never an "accepted" standards practice but was certainly done. It's because of installations like this that we now have "standards".....
______
post #20 of 30 Old 01-09-2013
rhr1956's Avatar
Bingo!!!!! We have a winner!!!!!!!!!!!!!!!!!!
What's wrong with the photo is;
In a marine application the double pole main breaker is intended to interrupt both the NEUTRAL/WHITE wire and the BLACK/HOT wire. The main breaker should not be jumpered like that to break only the BLACK/HOT wire.
The other major issue on this boat was that the AC/DC grounding bond tie was non-existent. The GREEN AC safety ground wire is to be tied to the ships DC grounding bus, it was not.
OK now thump chest and give two thumbs up!!
This is what the panel looked like a few hours later. Notice the difference in how it is wired. The top two wires, white and black are the AC input from shore. Out the bottom left of the breaker the white/neutral leads back to the AC neutral bus for distribution and the black/hot feeds the individual branch circuit breakers out the bottom right of the main AC breaker
If your boat is not wired to interrupt both BLACK/HOT and WHITE/NEUTRAL, in a fault, please get this fixed..
By looking at your work, I believe you could be a big help to me. I need to rewire my mast. Currently it only has a steaming light. I would like to add spreader lights and a masthead light. The mast is deck stepped with wiring internal. There are no external plugs or connections. There is currently two wires that power the steaming light which is disconnected by a two pin marine plug for mast removal. There are two more pairs that are stubbed out from the cabin top and terminated. The breaker panel lists the extra pairs as "spreader light" and "spare 1". The breaker panel also has a "spare 2" but I'm not sure where it's wire is run. I'm mechanically inclined but electrical stuff confounds me. Any recommendations for tackling the project would be must appreciated. The mast is currently in the backyard on saw horses and I'm rearing to go.
rhr1956 is offline
how do i add a picture TheMadchef General Discussion (sailing related) 2 09-14-2011 10:05 AM
What's wrong with this picture Gene T Gear & Maintenance 23 03-11-2010 09:38 AM
Big picture? Omatako General Discussion (sailing related) 11 01-06-2008 01:35 PM
What is wrong with this picture? tenuki General Discussion (sailing related) 19 06-11-2007 06:38 PM
Newbie: What's wrong with this picture MaineCub Learning to Sail 21 01-07-2007 07:28 PM
