Seaward water Heaters - SailNet Community
 2Likes
  • 1 Post By miatapaul
  • 1 Post By Stu Jackson
post #1 of 9 Old 01-09-2013 Thread Starter
Hello to everyone,
I have just joined and it is a pleasure to have found you. I belong to lots of different forums for lots of different reasons and i simply love the help that we all give each other.
Anyway, I have a 20 gallon Seaward water heater aboard my Silverton 453 and a couple of years ago it started leaking so i replaced it, if it were only in my engine room the way that the water heater was aboard my Trojan 400 i would have left the stupid drip alone.
So, I removed the old heater that was in the ceiling space above the mid stateroom head and of course i couldn't get it completely empty so about 2 gallons of the crappiest sludge went all over me and of course the head, shower, sink etc, thank god i have a wife that cleans for me...
Having installed the new heater which was very simple and a whole lot lighter i was elated until the past couple of months when i started noticing an earthy smell when i first turn on the hot water and even though i put an addadtive in the 200 gallon fresh water tank every now and then i just know that the sludge that was in my old heater is building up in this one and I was wondering if anyone knows how i can clean the whole system out keeping in mind that when you drain one of these things they always leave a few inches in the bottom of the tank because of the stupid placement of the flush valve.
Any help or suggestions will be greatfully appreciated and once again I am glad to have found you all.
regards,
Doug.
doorpro is offline
post #2 of 9 Old 01-09-2013
chef2sail's Avatar
Re: Seaward water Heaters
When you clean it and its almost empty use an air pump/ pressure on the intake...it will blow all the crap out of or a lot of it anyway. Put exit hose into a bucket so it doesnt get all over
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #3 of 9 Old 01-09-2013 Thread Starter
Chef2sail,
that is a great idea and i wondered would it also work to install a hose on the intake and a length on the exit (into the ocean) and flush it through with pressure?
regards,
Doug.
doorpro is offline
post #4 of 9 Old 01-09-2013
Old enough to know better
Originally Posted by doorpro View Post
Chef2sail,
regards,
Doug.
This seems to me the best thing, as air may push out some sludge the water will dilute it and rinse it. You should do this to your home heater as well.
Sent from my ADR6425LVW using Tapatalk 2
chef2sail likes this.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #5 of 9 Old 01-09-2013
chef2sail's Avatar
I use the Scaprego air pump we use to fill our dinghy. Runs a high pressure throug. We see crap in the bucket too when we do it.
Parkville, Maryland
Our blog-
post #6 of 9 Old 01-10-2013
Fill the water heater with hot/warm vinegar, at least to the level of the exchange pipes or elements, wait a few hours, then flush with hot/warm water. Use the pumping methods mentioned above.
Water may taste funny for a bit, and scale may occasionally emerge, but that's all good.
Enigma0 is offline
post #7 of 9 Old 01-11-2013
Stu Jackson's Avatar
You may also want to get into the HABIT of running the hot water tap even when you don't have hot water. This keeps the water moving through the heater. also, don't keep the heater plugged in and ON for any longer than you need to make hot water. Overheating the water tends to drop precipitates out (depending on the condition of your local water).
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #8 of 9 Old 01-11-2013 Thread Starter
All great ideas and i also talked with a friend that has a filter on his water hose which helps.
I did call the manufacturers of the heater and they recommend the hose idea as the air compressor is messy and not a controlled flow like water pressure.
What really amazes me is that these water heater manufacturers dont build these units with a drain down at the bottom of the tank because when i drained the last one i couldnt get the last gallon or so out until i tilted the tank. I'll plug that hole next time...
So i am going to try everything here and then add a filter to my filler hose. I
ll let you all know what transpires when i get to it...
Thanks to you all for the great suggestions..
regards,
Doug.
doorpro is offline
post #9 of 9 Old 01-11-2013
Fair winds, and golden strands.
Enigma0 is offline
Water Heaters captbaja General Discussion (sailing related) 15 09-14-2011 09:55 PM
Hot Water Heaters lgaggie96 Gear & Maintenance 7 04-12-2011 10:07 AM
Water cooled air conditioners / water heaters graypenguin Gear & Maintenance 2 11-28-2010 02:40 PM
Tankless hot water heaters amayotte Gear & Maintenance 2 02-22-2008 11:33 AM
water heaters tauras General Discussion (sailing related) 3 12-31-2003 05:11 AM
