Outboard Issue - Page 3 - SailNet Community
post #21 of 22 Old 01-18-2013
Sundance 23
carl762's Avatar
Re: Outboard Issue
Plus 1 on the Seloc manual. My Evinrude 9.9 is the same age as yours. Good book. Found a bunch of stuff online, through many searches, and filled a 5" thick notebook with material.
Do the plugs, and clean the carb. Did that myself, still had problems, only to find a small leak at fuel line connector where it attached to the motor.
Best of Luck!!!!
Water is Life
carl762 is offline
post #22 of 22 Old 01-18-2013
Brewgyver's Avatar
Re: Outboard Issue
Should you run into this again, you can get a rebuild kit for most carbs. It's also unusual for a carb that small to have problems that can't be solved with a rebuild, or often just a thorough cleaning.
I inherited a circa 1971 Johnson 4 hp from my Grandfather. It had sat in my grandparent's basement, unused, for over 20 years. I pulled out the carb, completely disassembled it, and cleaned all the parts with carb cleaner. The bowl, as I suspected, had not been drained after the last time it was run, and the residual gasoline had become a thick, jelly-like mess. Soaking a few hours and scrubbing a bit removed it. Reassembled and installed the carb, put a new raw water impeller in the lower unit, hung it in a barrel of water and it started on the 4th pull. I still use it on the 14' aluminum boat that it was purchased with.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
Tags
johnson , outboard , service manual
Outboard Bracket Issue YeahJohn Gear & Maintenance 7 12-02-2010 04:03 PM
GPS issue drynoc Gear & Maintenance 7 10-28-2008 04:53 PM
AIS E-80 issue thekeip Gear & Maintenance 3 10-02-2008 02:05 PM
ICW Issue tm3 Cruising & Liveaboard Forum 3 12-02-2006 09:41 AM
