Like Tree2Likes
  #21
Old 01-17-2013
blt2ski's Avatar
Re: Furler recommendation?
I thought of something else before hitting the sack here......11pm on the left coast of NA.....how is tomorrow shaping up?...........the luff has twin grooves does it not? no use having a removable drum with out the ability to draft the new with old sail going up and down etc!
Now that I am rereading, I believe I have heard of Furlex, but not as popular as harken or lewar among other furlers local. Profurl may have some sales.......I have a feeling, you and I would go after the same basic what we want out of a furler......one of these days I may get one..........
Marty
She drives me boat,
I drives me dinghy!
  #22
Old 01-17-2013
benesailor is on a distinguished road
I love my pro furler and don't think i would go with anything else if you want durability. It's tough as nails.
  #23
Old 01-17-2013
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Marty
G'day Marty. It's morning here - it'll be 30degC today but that's cooler than the 41 we had yesterday.. and as dry as a pizza oven. It's so dry here at the minute you don't actually sweat outside - it instantly evaporates off your skin - so keeping both cool and hydrated is a challenge.
Twin foils = check. Split drum = check. Internal rigging screw = (optional) check... $$$ = check.
Yep, they're not as popular as Harken (the Racers' Choice), Lewmar or even Profurl, maybe 'cause they're French - but I know a couple of people using them and nobody here (or anyone else I know) had anything particularly bad to say about them, so I figure they must be ok... right?
I've never really taken much notice of what various different furlers people are using - although you can spot the Black Harken a mile away. Having had a Furlex pointed out to me recently the conversation went more like: "Oh.. One of those! Riiiight.."
"Only two sailors in my experience never ran aground: one never left port and the other was an atrocious liar.." - Don Bamford
  #24
Old 01-17-2013
blt2ski's Avatar
Cam, I wish it were 30-40C here! try about 30F!!! or -1C or there abouts, foggy due to a temp inversion tween the two mtn ranges, no wind, pollution is not getting driven out etc......not fun. Oh, and freezing fog in some area's....not many, but it is still there......
anyway, not sure which furler I would get, other than those general "$$$$/check" terms you rattled off! Along with funds to recut one of my sails, or get a new one to fit the furler.......youch! I have a few other items I need more than a furler frankly!
Marty
She drives me boat,
I drives me dinghy!
  #25
Old 01-18-2013
knuterikt is on a distinguished road
Furlex is Swedish
Facnor is French
Profurl is French
Harken from USA
  #26
Old 01-18-2013
Hartley18's Avatar
Termite Fodder
Originally Posted by knuterikt View Post
Furlex is Swedish
Facnor is French
Profurl is French
Harken from USA
Oops.. my bad. I saw the accent on the "e" in "Selden" and assumed... wrongly.
No wonder the manual is so well written!!
  #27
Old 01-29-2013
Hartley18's Avatar
Termite Fodder
After four hours wrestling with the old one(*), assembling the new one, re-tensioning the rig and re-tensioning myself after paying the bill (isn't anything cheap these days?.. no, don't answer that ) I'm now the proud owner of a brand new Furlex 200S - and a bright, shiny thinghy it is too!!
..now to get the headsail sorted and I can go sailing again.
* = here's some of what we needed to go through: I'd forgotten that the forestay is fastened to a through-bolt that also carries the turning blocks for the two jib halyards, although the rigger reminded me fast enough when I sent him up on the main halyard to undo the forestay. After hooking up the spinnaker halyard for the temp forestay, that meant that, once he unfastened the whole shebang, there wasn't anything left to lower the forestay down - so, after thinking about this for a bit, he clipped one of the jib turning blocks to his bosun's chair(!) and we lowered away..
  #28
Old 01-29-2013
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Cameron,
Womboat furler that blew apart is a Furlex. in reality all that happened was the outer cover was UV degraded and it disintegrated. Replacement parts were not all that expensive and took ten minutes to fit. Although I bought replacements for both the inner and outer stays the inner is still the original and seems fine. I guess it is less exposed to the sun.
Andrew B
  #29
Old 01-29-2013
MarkSF is on a distinguished road
No problems with my Harken Cruising furler itself but the devil is in the detail of installation. It went from a reluctant, temperamental nightmare, to being 100% reliable, with two mods :
1) Halyard retainer at the top, so that the halyard can't catch on the furler swivel.
2) A ratchet block in the cockpit on the furling line, which keeps the line under tension. This helps the line coil on the furler without overrides, and has the useful side effect of making it easier to unfurl the sail controllably in stronger winds.
Bristol 31.1
  #30
Old 01-29-2013
Hartley18's Avatar
Termite Fodder
Cameron,
Andrew B
For some bizzarre reason I thought it was the Harken.. oh well, they're both black.
The Furlex does seem like a good unit - and that I can understand the Manual is a bonus. I'll be down there this arvo with the sailmaker to talk about adjustments to the headsail... then I get to go sailing again.
C.
You may post attachments
You may edit your posts
furler recommendation Grcesq Gear & Maintenance 2 07-13-2010 07:54 AM
Boat recommendation ebnewt General Discussion (sailing related) 8 07-13-2010 12:38 AM
VHF recommendation.... again... calden Gear & Maintenance 16 06-11-2010 09:34 AM
gps recommendation bestfriend Gear & Maintenance 13 12-11-2006 11:50 PM
Looking for recommendation stykman Gear & Maintenance 2 10-15-2004 07:10 PM
SEO by vBSEO 3.6.1
