Frozen Sail Slide - SailNet Community
 3Likes
post #1 of 18 Old 01-11-2013 Thread Starter
Learning Fast
Frozen Sail Slide
Pearson 32 with Kenyon aluminum boom has aft-most sail slug of bronze.
It will not move or come off. I had to cut the canvas strap to take off the mainsail and get it patched. Now trying to get that old slug off, I've tried:
  1. Rubber mallet
  2. Claw hammer
  3. hammer with screwdriver
  4. Liquid Wrench
  5. WD-40
  6. PB Blaster (type of penetrant)
  7. Heat gun
  8. Razor blade to ensure edges are free of gunk
Nothing has moved the slug. Today's effort with another sailor was 1,000 hammer taps of varying force from all 5 directions (cannot hammer from the bottom of the boom) after applying PB blaster and waiting for various time intervals.
Welcome suggestions from Those More Experienced, and Thanks!
Outrageous is offline
post #2 of 18 Old 01-11-2013
Re: Frozen Sail Slide
I like Kroil, but with any penetrating oil, time is your friend. Reapply and wait. Bronze, aluminum, and salt are a bad mix, good luck.
RobGallagher likes this.
WanderingStar is offline
post #3 of 18 Old 01-12-2013
blutoyz's Avatar
You are doing it right...keep soaking and tapping. I would get in there and pry the boom open a bit at the slider but that is me, I have been known to break crap by being impatient...LOL. A torch would do more than a heat gun but remember that it is aluminum.
Good Luck
blutoyz is offline
post #4 of 18 Old 01-12-2013
jimrafford's Avatar
You could also try a "come along" to the mast to leave it under tension while it's soaking. Be patient.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #5 of 18 Old 01-12-2013
Looking up thermal expansion coefficient suggests that aluminum will expand slightly more than bronze when heated. However, that might mean the aluminum expands into the bronze on the slide, while the bronze expands out to the aluminum and holds it more firmly. Admittedly, I would still try it.
Another thought is to get some get some mild acid in there to start eating away at the likely corrosion that is causing this problem. Maybe Lime Away or even straight vinegar. The trick is going to be keeping it on the part while it works. Vinegar will dissolve metal entirely, so it really could work, if you get it in there.
Edit: diluted vinegar would eat corrosion off dive parts in 15-30 mins. This may take longer, but I would get hours, not days.
Jeanneau 54DS
Minnewaska is offline
post #6 of 18 Old 01-12-2013
Senior Smart Aleck
jameswilson29's Avatar
Hacksaw, drill, screwdriver, hammer...destroy and replace.
Silvio likes this.
jameswilson29 is offline
post #7 of 18 Old 01-12-2013
Battered and Bruised
Silvio's Avatar
I would be inclined to go the route suggested by jameswilson29, dremel tools are good at grinding in tight areas or even an high speed air grinder. I would try to take it out in pieces.
SV S.S.R.I
It's my happy pill
Silvio is offline
post #8 of 18 Old 01-12-2013
Hitting it with a claw hammer and screwdriver isn't using the best tools for the job. You need a lump hammer and cold chisel, these will have far more effect with greater control and safety. Also make sure you are using eye protection.
-OvO- likes this.
MarkSF is offline
post #9 of 18 Old 01-12-2013
Soak with PB Blaster; use a 3-5 pound mash hammer and dull cold chisel. A couple good whacks should do it. Wear a pair of heavy leather gloves, at least one on the chisel hand if your aim goes awry.
Seaduction is offline
post #10 of 18 Old 01-12-2013
snake charmer, cat herder
zeehag's Avatar
the tool is a coal chisel--not a cold chisel--oops did i say that out loud????
formosa 41, cruising tropics
zeehag is offline
Sail slide / slug shackle size? MITBeta Gear & Maintenance 3 05-09-2012 04:46 PM
Lubricating sail slide CapnRon47 Gear & Maintenance 14 09-14-2010 08:44 PM
Hatch Slide Hardware henryyork Gear & Maintenance 1 06-01-2009 01:34 PM
Can anyone identify this track and slide? SteveA Gear & Maintenance 3 05-25-2009 12:23 AM
Mainsail slide systems psotis Gear & Maintenance 11 09-10-2006 10:10 PM
