Like Tree3Likes
  #31
Old 01-16-2013
chef2sail's Avatar
chef2sail will become famous soon enough
Re: Life Lines? West marine and crimp?
Originally Posted by ltgoshen View Post
I may have answered my own question
I found it on Johnsons website. the Toggle Jaw with Eye to the Bow pulpet.
[Johnson Lifeline Toggle Jaw with Eye - Fittings for Dyneema Lifelines - Lifeline Hardware - Rigging, Spar & Lifeline Hdwr - Downwind Marine
Then, I would use the Pelican Gate Hook with Eye on the stern pulpet.
Johnson "Over Center" Pelican Gate Hook with Eye - Fittings for Dyneema Lifelines - Lifeline Hardware - Rigging, Spar & Lifeline Hdwr - Downwind Marine
Where would I add the turn Buckel?
Johnson Tubular Lifeline Turnbuckle with Eye - Fittings for Dyneema Lifelines - Lifeline Hardware - Rigging, Spar & Lifeline Hdwr - Downwind Marine
Or would I use the Turnbuckle instead of the Toggle Jaw with Eye?
The wire is not the expensive part...its the fittings. The barrels are the way to pull in the slack as the wire stretches. You have 4.....2 in the two long rubs, both attached at the welded rings with the toggle at the bow, and 2 in the stern attached to the welded ringsdon the stern tubbing.
Also in the winter i let them go slack.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #32
Old 01-16-2013
Brent Swain is on a distinguished road
I use stainless 1 1/4 inch OD boiler tubing, 34 inches off the decks. Once you have cruised with solid lifelines you will never go back to wire.On a fibreglass boat it drastically reduces the loads and movement on the stanchion bases, drastically reducing the chances of leaks there.
For the lower lifeline nothing beats 1/4 inch 1x19 stainless rigging wire.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
  #33
Old 01-17-2013
Stumble is on a distinguished road
I would love to see the push pulpit connection? there is a welded ring on mine. Do you loop it and splice it there ? or add something. How do you connect the thimble to the welded ring on the pulpet?
Sorry i'm new at this
For the bow end I splice an eye then ring hitch the eye around the bow pulpit with the tail passing thru the welded ring. http://nodulous.files.wordpress.com/...-abok-1859.jpg
Then rove it back thru the stantions. At the end toss in another eye splice around the thimble. Then use a lashing to connect the lifeline to the stantion.
Greg Rubin
Titanium Salesman
  #34
Old 01-20-2013
First String
ltgoshen is on a distinguished road
I placed an order today with Go2Marine for 66 feet of amsteel X 3/16 at $0.95 then I ordered 66 Feet of Amsteel Blue X 1/8 at $0.46 I need to find the pelocan hooks with splice ends. I also ordered the 4 thinbles total so far $86.49 Anybody know were to get 2 pelican hooks with splice ends on them let me k now.
Thanx
  #35
Old 01-20-2013
davidpm's Avatar
davidpm is on a distinguished road
Originally Posted by MarkSF View Post
I agree with all those points but I have brand new, uncoated, s/s wire. How would dyneema be SAFER?
If you have someone in the water one really big problem is getting them over the lifelines. With fiber life lines if you have a very very sharp knife you can cut them.
If you have a hand on someone overboard getting them to the rail might be possible but lifting them another 30 inches over the lifeline is not likely.
If you have new wire lines it is unlikely that you would replace them for that reason but the above reason has been sighted as a safety feature.
And the same is true in an dis-masting. All fiber standing rigging and lifeline would be much easier to clear and could save lives and a boat in some scenarios.
  #36
Old 01-20-2013
Itgoshen,
Check out Johnson "Over Center" Pelican Gate Hook with Eye - Fittings for Dyneema Lifelines - Lifeline Hardware - Rigging, Spar & Lifeline Hdwr - Downwind Marine
Greg Rubin
Titanium Salesman
  #37
Old 01-20-2013
First String
Originally Posted by Stumble View Post
Thanks, I just ordered 2 for the new am-steel when it comes in.
  #38
Old 01-20-2013
First String
I ordered thimble for splicing to the bow. and Rope from Go2Marine. So here is how it was paid out.
The rope I got for
$o.46 for the 1/8 66 feet
then $0.93 for the 3/16 Dyneema
4 Thimbles
For a total at Go2Marine with shipping $86.49
complete new lifelines $120.00
$120.00 bucks for the 2 with 2 day air shippin 206.49
I will do the splicing my self. There are some good utube examples. Iam just not sure how to get it real tight onto the thimbles.
Thanks for all of your advice It helps NOOBS like make better choices.
I will have photos in a few days.
Here is a short video of me there today at the boat.
https://www.youtube.com/watch?v=j0xX4UHbwtY
  #39
Old 01-20-2013
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Good onya. 3 hours to clear vinyl off old lifelines doesn't sound like fun. You could've had the new stuff installed in that amount of time.
Couple things,
1) make sure your bury is 72x the diameter of the line. That's 13.5" for the 3/16" and 9" for the 1/8" stuff.
2) be sure to do a proper gradual taper. The splice will first fail at the end of the taper.
Gates are nice, but unless there's a double set of lifelines, I usually just lash in place and step over the line.
Merit 25 # 764 "Audrey"
You may post attachments
You may edit your posts
Life Lines and a 3 year old... DubeJ C22 6 12-30-2012 06:31 PM
Life lines bofus1 General Discussion (sailing related) 10 05-27-2010 06:10 PM
help me, life lines, halyards, jib sheets diverdad69 Gear & Maintenance 11 06-02-2009 06:53 AM
Life lines and other confusion AllThumbs Gear & Maintenance 19 02-07-2009 10:11 AM
Life Lines vardaman7 General Discussion (sailing related) 28 07-24-2007 08:18 AM
SEO by vBSEO 3.6.1
