Toe rail cap - Page 2 - SailNet Community
 2Likes
post #11 of 22 Old 01-16-2013
Re: Toe rail cap
Originally Posted by Minnewaska View Post
Sent an email this morning and they replied as soon as I assume they arrive in the office in UK. I'm always very impressed by that kind of responsiveness to a potential client. Highly recommend dealing with this company for that reason.
However, while they could custom cut, their applique won't adhere to teak, it requires gelcoat.
Still searching for a solution.
That's a shame, but you're right, it was a great response to your note!!
(Gel coat your top rail at the gates!
Faster is offline
post #12 of 22 Old 01-16-2013
Once known as Hartley18
Classic30's Avatar
Dock
Re: Toe rail cap
Thanks for the pic. Unfortunately, the toe rail is convex, so the tread needs to be curved along its length.
Even if it's a little convex, I wouldn't write-off using brass. As I see it, there are a couple of options:
1. You could sand the top of the toe-rail flat to the width of whatever brass strip you got. Since the top of the stair-tread stuff is slightly convex anyway, it will naturally follow the curve and look like it has always been there..
2. You could have something worked up for you at the local foundry/engineering shop. Given that you'd be starting with a thin strip of flat-bar and wanting a slight curve hammered in it (brass is comparatively soft and not difficult to work) it should be a less expensive option than you think.
I also have chafe protection, but they are only about a half inch wide and a foot long and sit atop the toe rail's highest point. I've thought about putting a few of them parallel to each other, where the foot tread needs to be, but think it may look bad.
Yep - don't do that. It's not that it'll look bad because I've seen people do this and it doesn't look great but it's not horrible either - it's that the gap between the strips cannot be properly cleaned out and the dust/dirt that collects there gets forced into the timber grain. That looks bad!
IMHO, brass strip really is the way to go for this: it will look fine and will last as long as the boat.
Classic30 is offline
post #13 of 22 Old 01-17-2013 Thread Starter
Re: Toe rail cap
Love brass, but unfortunately, there is none above deck on our boat. Stainless, teak, white gelcoat and dark blue paint are the only colors. I fear it would look out of place right at the lifegate. It may have looked better if we kept the toe rail varnished.
The cross section of our toe rail looks a bit like a huge piece of quarter round. There is a flat inside edge that is perpendicular to the side decks. The outside edge is convex, which is predominantly what you step on, at least the upper portion of it.
Jeanneau 54DS
Minnewaska is offline
post #14 of 22 Old 01-17-2013
Re: Toe rail cap
These are nice.
Seaduction is offline
post #15 of 22 Old 01-17-2013
Re: Toe rail cap
I doubt Minne wants an IP step tread... but the picture does offer up an option... make up a similar teak 'leveling' piece and put a flat SS plate onto that.. you can buy polished SS checker plate that may have some non skid properties..
Faster is offline
post #16 of 22 Old 01-17-2013
Sailing Junkie
ehmanta's Avatar
Re: Toe rail cap
How about a piece of sacrificial teak along the same idea of that Island Packet plate? You could cut saw kerfs longitudinally along the top of it to help out with the traction, dirt and grit plus the kerfs would hide any scuff marks. You can easily make the bottom of this strip concave by running on a diagonal across a table saw blade, as long as you clamp an auxiliary fence to the saw.
Classic30 likes this.
"Dragonfly"
Tartan 4100, #28
ehmanta is offline
post #17 of 22 Old 01-17-2013
Re: Toe rail cap
Right, he wouldn't want that on his Jeanneau. That was just a little 'fun jab.'
post #18 of 22 Old 01-17-2013
Old enough to know better
Re: Toe rail cap
Originally Posted by Seaduction View Post
These are nice.
I think this would slow his boat down too much!
miatapaul is offline
post #19 of 22 Old 01-17-2013
Re: Toe rail cap
Yeah....I know. Sometimes my boat is so slow that I sail backwards! ...and I don't even have step pads!
post #20 of 22 Old 01-17-2013
Senior Moment Member
SloopJonB's Avatar
Re: Toe rail cap
These are nice.
How about one of those cutesy brass plates that says "The Captains Word Is Law"?
Some of them are pretty big and stepping on them regularly seems like a REALLY good idea.
SloopJonB is offline
rub rail ncsc Cal 15 09-18-2014 06:40 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
New Toe Rail Bermuda30 Gear & Maintenance 1 08-14-2008 06:36 PM
Rub rail brak Gear & Maintenance 4 05-06-2008 03:33 PM
S-2 Rub Rail Hymie Gear & Maintenance 1 10-27-2004 08:44 PM
