Toe rail cap - Page 3 - SailNet Community
 2Likes
post #21 of 22 Old 01-18-2013 Thread Starter
Re: Toe rail cap
I doubt Minne wants an IP step tread... but the picture does offer up an option... make up a similar teak 'leveling' piece and put a flat SS plate onto that.. you can buy polished SS checker plate that may have some non skid properties..
By George, I think we've got it!
It might be a small challenge to scarf a piece over the rail, but that's doable.
The sacrificial thought may be possible, if I could think of a way to reproduce it easily, but I like leveling it out and having a stainless tread.
Many thanks.
Jeanneau 54DS
Minnewaska is offline
post #22 of 22 Old 01-20-2013
tap
Re: Toe rail cap
You could make a leveling shim with epoxy. Might not look quite as nice as teak, but probably a lot easier and cheaper.
What you do is put some plastic wrap tightly onto the toerail to keep anything from sticking. Put a couple layers of glass down and wet them out. Then put some thickened to peanut butter consistency epoxy down on top of the glass. A blob about the size of the plate you'll put on top. Now smoosh it flat with your plate, also protected with plastic wrap or some other kind of mold release on the bottom. Put a nice filet on the edges. When it cures you'll have a perfectly shaped shim that goes between the toe rail and plate. Trim off the excess glass on edges with some scissors.
You'll want to paint the exposed edges of the shim to protect it from UV damage. It will look nicer that way too. A black border around the stainless from the filet of epoxy might look nice.
tap is offline
rub rail ncsc Cal 15 09-18-2014 06:40 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
New Toe Rail Bermuda30 Gear & Maintenance 1 08-14-2008 06:36 PM
Rub rail brak Gear & Maintenance 4 05-06-2008 03:33 PM
S-2 Rub Rail Hymie Gear & Maintenance 1 10-27-2004 08:44 PM
