Like Tree2Likes
  #1
Old 01-13-2013
Minnewaska will become famous soon enough
Toe rail cap
I've seen boats with a nice brass or stainless cap on their toe rail beneath the life gate. It's a great idea. We removed the varnish from the toe rail last season and liked the look, not to mention the reduced maintenance.
However, the toe rail is stepped on and is getting dirty and even minorly worn. I can't think of a practical way of having a custom stainless cap made.
Any ideas of a method to protect it?
Jeanneau 54DS
  #2
Old 01-13-2013
Re: Toe rail cap
Have you seen this stuff?? Used as chafe guards on coamings and cabinsides etc.
Wear and Tear Pads | Self Adhesive Stainless Steel | Fiberglass Protection..
I've also seen clear non-skid self adhesive tapes too.
  #3
Old 01-13-2013
Re: Toe rail cap
Cool stuff. If it came in larger pieces, it may have been the trick. The life gate opening must be two feet wide and I would like to cover as much of it as possible. Even 14"-18" would probably do the trick.
Jeanneau 54DS
  #4
Old 01-13-2013
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Re: Toe rail cap
I've done a couple boats ( step/wear pads ) where I use fineline tape, system 3 clear epoxy and fine silica sand.
Looks pretty dang good with and without a varnished caprail
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
  #5
Old 01-15-2013
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Re: Toe rail cap
The brass stuff you've seen on older () boats is usually just flat-bar cut to length with the sharp edges filed off and a screw each end to hold it on. It's sold in hardware stores for stair-tread protection and comes in standard lengths you cut down with a hacksaw.
I'm sure you could do the same with stainless, but highly-polished stainless would show scratches more readily - from people stepping on it from the dock with bits of gravel in the soles of their shoes..
If you've bare timber, go with the brass. Unless polished up, it'll go green eventually but will protect your toe rail forever. ..it's also good for dock-line chafe protection:
(with apologies for the crummy photo - taken for other reasons)
SloopJonB likes this.
"Only two sailors in my experience never ran aground: one never left port and the other was an atrocious liar.." - Don Bamford
  #6
Old 01-15-2013
Re: Toe rail cap
Worth a call to the manufacturer to see if they'll custom cut??
  #7
Old 01-15-2013
chucklesR's Avatar
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Re: Toe rail cap
There is, in my opinion, only one way to do it -
Read, laugh, learn, or just enjoy
  #8
Old 01-16-2013
Re: Toe rail cap
Originally Posted by Hartley18 View Post
The brass stuff you've seen on older () boats is usually just flat-bar cut to length with the sharp edges filed off and a screw each end to hold it on......
Thanks for the pic. Unfortunately, the toe rail is convex, so the tread needs to be curved along its length.
I also have chafe protection, but they are only about a half inch wide and a foot long and sit atop the toe rail's highest point. I've thought about putting a few of them parallel to each other, where the foot tread needs to be, but think it may look bad.
The idea of a tread came to me because a friends has a Taswell will a gorgeous brass thread at the lifegate, but its OEM.
Jeanneau 54DS
  #9
Old 01-16-2013
Re: Toe rail cap
Good idea. I sent them a note to find out. Looks like they are in England.
Jeanneau 54DS
  #10
Old 01-16-2013
Re: Toe rail cap
Sent an email this morning and they replied as soon as I assume they arrive in the office in UK. I'm always very impressed by that kind of responsiveness to a potential client. Highly recommend dealing with this company for that reason.
However, while they could custom cut, their applique won't adhere to teak, it requires gelcoat.
Still searching for a solution.
Jeanneau 54DS
You may post attachments
You may edit your posts
rub rail ncsc Cal 14 09-22-2009 05:15 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
New Toe Rail Bermuda30 Gear & Maintenance 1 08-14-2008 06:36 PM
Rub rail brak Gear & Maintenance 4 05-06-2008 03:33 PM
S-2 Rub Rail Hymie Gear & Maintenance 1 10-27-2004 08:44 PM
SEO by vBSEO 3.6.1
