Like Tree5Likes
  #1
Old 01-14-2013
Baloo_it's Avatar
Baloo_it is on a distinguished road
Climbing the mast
Hello,
On my boat invicta 26 I would like to install a system to climb up the mast.
I found these removable systems: ATN Mastclimber , MastMate or Topclimber but in my opinion they all cost too much ($ 3-400).
The alternative and mybe the better choise is to install the steps on the mast. But since in this case the prices are a real robbery the solution would be to selfmade the steps from a flatbar fastened with rivets.
In your experience what is really the easiest and cheapest way to climb up the mast (also alone)?
Thanks
RUGGERO
My dream coming true is a nonstop singlehanded Atlantic Ocean crossing from Blackpool to Amazon
  #2
Old 01-14-2013
Minnewaska will become famous soon enough
Re: Climbing the mast
Most 26ft boats are going to be fairly sensitive to having additional weight on the mast. In fact, many aren't going to like having a climber at all, let alone permanent steps.
Do you have an routine need for going up the mast? If not, I would just unstep it when you need to do something.
Jeanneau 54DS
  #3
Old 01-14-2013
jameswilson29's Avatar
Senior Smart Aleck
jameswilson29 is on a distinguished road
Rope climbing gear. Climb with a harness, ascenders, and aiders. No fuss, no muss.
jrd22 and Flybyknight like this.
  #4
Old 01-14-2013
cookwithgas's Avatar
cookwithgas is on a distinguished road
I purchased an ATN mast climber and have used it twice. It takes a good bit of energy to get to the top, but it works. I always plan to have a second person on a spare halyard and winch just in case something gives. Good luck!
  #5
Old 01-14-2013
marcusc130's Avatar
marcusc130 is on a distinguished road
Climbing the mast
Just FYI, you can put together your own ATN setup for about half the price from REI or any other outdoor sports shop. It's simply a harness and Prussik setup, and I'd use that over the mast steps any day.
  #6
Old 01-14-2013
harbin2 is on a distinguished road
I have a Mastmate for my 30' Islander. It works great. You must remove the mainsail slugs and that's a pain but it's very easy to climb and you need no assistance.
  #7
Old 01-15-2013
knuterikt is on a distinguished road
Mast steps add weight to the mast and tend to snag halyards.
I have tested different solutions for climbing or help the person at the winch hoisting me.
This movable step is made of a piece of plywood, one cleat and two eye straps.
You need a free halyard to put the step on.
I use it with a good bosuns chair like this - I strap securely into this.
When going up the mast with a helper on deck the procedure is like this.
1) I stand on the step.
2) Helper take the slack on the halyard's (use two for safety)
3) Lift the step using my foot
4) Stand up in the step
Repeat 2-4 until at the top
Doing work at the top can get awkward hanging in a bosuns chair.
If I need to get higher up I can stand on the step.
Going down i bring the step with me as my helper lower me down.
I have found that this step is more stable than foot loops.
This step can be used in combination with ascenders if you like to climb solo.
  #8
Old 01-16-2013
VallelyJ is on a distinguished road
I'll second Marcusc130.
PS reviewed several systems a year or 2 back and one of their highly-rated climbing harnesses was a Petzl rock climbing harness with stainless steel hardware for a couple hundred bucks. I bought a mid-range Petzl rock climbing harness at EMS on sale for $60. It has anodized hardware. As long as I don't store it in brine I figure it will last only about 190 years, instead of 200. I'll take the risk.
The whole rig, including 3/8" utility line, some webbing and anodized locking carabiners, was less than $100. I go up my 40' mast quite easily without any assistance from the deck.
The sit-harness is adequately comfortable for the kinds of jobs I've had to do up there. I don't think you need to spring for equipment made, and priced, for the boat market. Rock climbing gear is just as reliable, and people use it in salty coastal areas just as they do inland. Just make sure your halyards are up to the job. Having faith in your gear makes mast climbing pretty stress-free.
One tip--if you make web slings for your feet, join them with about a foot of webbing, so your feet stay beside the mast.
John V.
jrd22 likes this.
  #9
Old 01-16-2013
justified is on a distinguished road
knuterikt - Nice rig If you don't mind I'm gonna copy it. Simple and safe.
Peter
  #10
Old 01-16-2013
Peter
Please copy I have copied the design from others
The measurements in this picture are mine.
You may post attachments
You may edit your posts
Mast climbing davidpm General Discussion (sailing related) 61 11-28-2012 06:28 PM
Climbing the mast pkats Gear & Maintenance 31 07-02-2009 11:40 AM
Climbing the mast kmeeks Gear & Maintenance 11 01-10-2003 01:55 PM
Climbing the mast word2rapp Gear & Maintenance 3 11-15-2002 10:57 AM
Mast Climbing RichardElliott Gear & Maintenance 17 04-19-2002 04:44 AM
SEO by vBSEO 3.6.1
