A lot of slack on the tiller - SailNet Community
post #1 of 8 Old 01-15-2013 Thread Starter
I need some advice. The bronze hardware on the tiller of our '66 pearson wanderer fits pretty loose on the rudder post. I'm wondering if it can be squeezed shut to take out some of the slop or will this cause the metal to break. There is about 1/8 inch on each side of the rudder post. This creates quite a bit of wobble when sailing downwind or motoring. All the rest of the rudder assembly is tight.
CLOSECALL is offline
post #2 of 8 Old 01-15-2013
Seņor Member
PorFin's Avatar
Re: A lot of slack on the tiller
Close,
Can you post a picture of the tiller to post connection?
________
'85 BYB Vagabond 39
PorFin is offline
post #3 of 8 Old 01-15-2013
blutoyz's Avatar
You can't put some shims in there to take up the slack without stressing anything?
blutoyz is offline
post #4 of 8 Old 01-15-2013
chucklesR's Avatar
Shim it up tight with washers or wooden wedges, not so tight as so it won't lift and turn proper.
chucklesR is offline
post #5 of 8 Old 01-15-2013
rhr1956's Avatar
I would not try and bend it. Instead take the advice above and use something to fill the gap. Maybe several wraps of rigging tape around the shaft? Then tighten the sucker up.
rhr1956 is offline
post #6 of 8 Old 01-15-2013 Thread Starter
o.k. and thanks. I'll try some kind of shim. Sorry I can't get a photo as I am not near the boat.
post #7 of 8 Old 01-15-2013
Tim R.'s Avatar
If you are saying the bearing is elongated like an oval, a shim will not work. The only solution I know is to either replace the bearing or have it welded(filled in) and re-bored. either requires removing the bearing. I am not sure if you need to remove the whole rudder though. I did this job on my '76 Pearson 28-1 and only had to lower the rudder about 6 inches.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #8 of 8 Old 01-16-2013
If you're going to try shimming, try using a section of the wall of a plastic, soda bottle. It's slippery, cheap, and doesn't swell when wet.
Hudsonian is offline
Slack Tide vs. Slack Current Sabreman General Discussion (sailing related) 70 03-04-2011 11:46 AM
slack in forestay freddyray Gear & Maintenance 6 08-29-2009 12:08 PM
Rapids question: slack tide vs slack current dancamp Cruising & Liveaboard Forum 4 08-24-2007 10:57 PM
Floating Dock Lines:Tight or Slack? s.slater Seamanship & Navigation 4 06-13-2006 11:02 AM
Docking lines:tight or slack? bmcald Gear & Maintenance 7 05-09-2002 01:29 PM
