Keel J bolt replacement in lead keel - Page 3 - SailNet Community
post #21 of 27 Old 01-15-2013 Thread Starter
A New Adventurer
funjohnson's Avatar
Re: Keel J bolt replacement in lead keel
Originally Posted by eherlihy View Post
Broomfield charged $450 per bolt in 2010. This is detailed in the post that I linked to above.
I was hoping your post before was a high estimate... now I just need to find out how much shipping would be. Wonder if I can get it into a uhaul truck?
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
post #22 of 27 Old 01-16-2013
I found this from a Don Casey article that was linked at the bottom, its a little reassurance.
" Except on radical race boats, keels rarely fall off. The reason is that a huge safety factor is nearly always designed into the attachment system. Nevin’s Rule calls for one square inch of bolt section for every 1,500 pounds of ballast. Both galvanized steel and bronze have tensile strengths of around 60,000 pounds per square inch, so if a builder follows this rule, the bolts attaching a 4,500 pound keel are capable of supporting 180,000 pounds—a margin of safety of 40 to 1. Of course, the static load increases with heel, and we can only guess at the dynamic loads, but in a recreational boat neither is likely to test or even approach such bolt strength."
Keel Bolt Concerns
Freerider is offline
post #23 of 27 Old 01-16-2013
One of None
deniseO30's Avatar
Keel Bolt Concerns
Sounds good.. but when they go, it's the shoe that lets loose.. Like mid 80s Catalina 30s used plywood in there...
20-40 year old FG that's had water in if most of those years.. is not really all that strong either.
My last project!
deniseO30 is offline
post #24 of 27 Old 01-16-2013
Figure out the dimensions/weight on a pallet & go to uship.com. Put it up on the site & you'll have folks bidding on the shipment.
Might be cheaper than driving a uhaul...
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #25 of 27 Old 01-16-2013 Thread Starter
A New Adventurer
funjohnson's Avatar
Have it up on U ship right now. I'll how low the bidding goes... so far it is $1300
mjsailing.com
post #26 of 27 Old 01-16-2013
Looked at your ad, you've got 6 days left. It'll come down to a grand or a little lower.
The guy that wants to put it in the back of a 1 ton van, guess he can't read
misfits is offline
post #27 of 27 Old 01-19-2013
blutoyz's Avatar
Did you ever see the show about the u-ship contractors? I think is is called shipping wars...just be happy that this is a chunk of lead because I don't think even they could break lead.
blutoyz is offline
Keel bolt replacement Qben Tartan 3 02-10-2011 07:24 PM
CAL 20 Keel bolt replacement Calabego Cal 1 12-21-2008 04:24 PM
Columbia 34 MKII Keel Bolt replacement JimKitzler Gear & Maintenance 0 06-05-2005 10:36 AM
Steel Keel vs.Lead Keel Rondolais Chartering 1 12-24-2003 03:28 AM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
