Installation & Orientation of Flooded Batteries - SailNet Community
 16Likes
post #1 of 13 Old 01-15-2013 Thread Starter
Maine Sail's Avatar
Port to Starboard Orientation
In the photo below I am simulating a sailboat heeling with flooded batteries. For years I have been wanting to write this article but until my friend Dave let me shoot these polycarbonate cased UPS batteries it was going to be tough to explain. A picture is worth a thousand words. This one may be worth more than a thousand...
Here we can see the three individual cells of this 6V battery. A 12V battery would have 6 cells. Even heeled like this the positive and negative plates are not and have not "uncovered" and this is good. The vents are also not having electrolyte try to escape out the vent holes. In a port starboard orientation, like this, the cells are in their "thin" orientation compared to port or starboard tacks. In 6V golf cart batteries, as well as groups 24, 27 & 31 12 volt batteries, cells oriented port to starboard, not bow to stern, is the preferred method for installing flooded batteries on a monohull sailing vessel.
Sorry for just telling you this now, if you have them oriented non-optimally, but I needed the pics before the article could happen. I apologize that you've also not heard about this from the industry experts either. Thousands of regurgitated articles in sailing magazines but I've never seen a single article deal with the the proper orientation of flooded batteries on monohull sailboats.. Sad really...
This is a problem I discovered back in the late 80's. I was on a friends fathers boat that we had put a "state of the art" charging system on due to chronic short battery life. At the time we incorrectly assumed it was "overcharging" or what we through at the time was "overcharging"... Even after the new alternator and regulator he still had short battery life.
He went through the first bank in less than a season. One day while helping him work on it I noticed electrolyte spilled in the cases. The plastic cases for the batteries were black and so were the battery boxes so it was tough to see.
I removed the batteries and discovered quite a bit of electrolyte. I cleaned it out, neutralized the acid, and we went for a sail with no charging. We put her up on ear beating to weather and sure enough electrolyte began to drain out of the batteries fill/vent ports.. The cases were not cracked or leaking but it was spilling out when heeled.
It then dawned on me that the orientation of batteries on sailboats mattered. Doh'........
I looked at the cell layout, and fill/vent ports, and simply rotated these batteries to port/stbd. After that quick fix he never again had a single drop of spilled electrolyte. This may NOT be an easy fix on all boats as many builders really stiff you one this...
If I recall that bank lasted 5 or 6 years, after those first few days of spilling. This after multiple years of replacing batteries almost annually. I can't say all the issues were related to the exposing of his battery plates, and chronically low electrolyte, but it certainly did not help any.
This problem is only compounded with batteries that have "off set" fill caps meaning they are closer to the edge of the battery than the center. Orient offset cap batteries in a bow/stern orientation and you'll have some real leakage issues on one particular tack....
Exposing the plates, especially under charge or discharge, can lead to shorter battery life. Is a failure immediate and catastrophic? No, but if the opportunity exists to orient them more optimally then it should be something you consider. Monohull sailboats should ideally have flooded batteries installed to minimize electrolyte spillage and to minimize or prevent the positive and negative plates from uncovering during normal sailing activities.
Bow To Stern Orientation
Here we have the same battery only now it is oriented with the cells running bow to stern. As you can easily see the positive and negative battery plates are exposed and uncovered from the electrolyte. On these batteries spilling is not an issue due to the height and design but on the typical 12V "marine" group 24,27,31 etc. this can not only lead to exposed plates but also electrolyte leakage if the heel is extreme enough.
Exposing or uncovering of the positive and negative plates of a battery from the electrolyte, especially when under load or when being charged, is not good for the battery. Even if you are not spilling electrolyte you may be exposing the plates.
Seeing as most sailors are using the batteries to power house loads, while they are sailing, proper orientation of the cells can be that elusive piece of the puzzle that finally leads to longer battery life.
You may have invested thousands of dollars in solar, wind, regulators, alternators, desulphators, temp sensing, fancy chargers, new large gauge wire, bank fusing and more, but if your batteries are not oriented optimally you're likely still missing that last piece of the puzzle...
Side Profile = Uncovered Plates
Here is a close up and side profile of what happens when the batteries are installed non-optimally. This battery was also at the low level for electrolyte. If it was full to where it should be then leakage could have occurred in a good puff. Either way the positive & negative plates are exposed and this is not good for the battery.
Fill Levels
There are differences between 6V batteries and the typical 12V batteries used in marine applications in regards to orientation and design.. These points are rarely if ever discussed.
In this photo you can see the blue line representing low mark for electrolyte levels, and this battery needs topping up. The bottom line is the low mark and the top blue line is the full mark. Even at low this battery still has sufficient electrolyte covering the plates to sustain typical heeling angles if properly oriented. This battery is very similar in design to a typical 6V GC2 or 6V T105 type battery.
6V deep cycle batteries are taller than a typical "marine" group 24, 27 or 31 12V batteries. Why? They are sold and used most widely in golf car applications and the added height benefits these batteries in two important ways.
#1 The added height, in some designs but not all, gives more electrolyte depth covering the plates when compared to typical 12V batteries. Golf carts are often driven on hilly terrain, parked at steep angles and this type of movement is closer to what a monohull sailboat undergoes. Only off road jeeps and four wheelers often put flooded batteries through the same pains as a golf car or sailboat, but rarely stay at these angles for hours...... This added case height and electrolyte depth can allow for less chance of the plates uncovering when the golf car moves about on hilly terrain and longer periods of time between watering...
#2 In deep cycling applications, like golf cars or sailboats, sulfation of flooded batteries is just a fact of life. The bottoms of 6V battery cases are deeper allowing for the collection of more shed lead sulfate. This battery shows very little sulfate in the bottom of the clear case but I have seen autopsied batteries with a "snow" covering of lead sulfate in the bottom of the case. 12V batteries can be "shorted" internally sooner than a 6V due to the build up of lead sulfate which eventually can reach the plates and short across them. This is more rare in 6V deep cycle batteries.
Fill Levels
A Proper Orientation
While this picture shows the battery cells lined up port to starboard, this is not how they shipped from the factory. This entire battery compartment was re-configured to allow for a larger house bank of two group 31 12V batteries plus a group 27 starting battery. The factory installation had the batteries bow/stern and only had room for two group 27's..
Port/Starboard
I like this picture because if you look closely you can see the cell divisions dimpled into the top of the plastic battery cases. Look at the faint lines and you can count all six cells on each battery.
This is an example of a good factory installation on an older Sabre 34 MK I. At the Annapolis boat show, this past fall, the Sabre I was on still had properly oriented batteries! Nice job Sabre...
While this battery compartment is small, at least by today's standards, the batteries are properly oriented and that is a good thing..
Port/Starboard
Builder Blunder
I will certainly give kudos to builders who do it right but there is no need to slam an out of business builder by calling them out by name. Those who own this model will know this battery compartment well. Sorry.......
This owner has actually unknowingly did a good thing by installing AGM batteries. Of course they lasted all of two years, on a mooring, but that is a topic for another day. Everything on a boat seems to be a compromise...
Unfortunately this builder left no possibility for a proper installation of flooded batteries short of cutting fiberglass and reconfiguring the battery tray. There is no way, in this tray, to orient the batteries any way other than bow/stern. Doh'....!
On a boat like this GEL or AGM batteries will likely be a good alternative option.
Builder Blunder
Mounting
Any discussion about battery installation would be incomplete without addressing securing the batteries into the vessel.
For this task I often prefer a set of heavy duty pad eyes and some canoe/kayak straps.. The other pad eye in this photo is for the house bank which has not yet been installed into the battery tray. Containment of acid is critical so that any metal tie downs don't get compromised by acid. For containment plastic battery boxes suffice.
Also important is that the battery box not be able to move fore, aft or side to side. In this installation it is entrapped by a 1.5" tall X 1.5" wide mahogany frame on the battery platform. There are many ways to secure your batteries, just be sure you do..
A good way to think about installing your batteries is to mentally visualize your boat in a knock down. So, take a moment to picture your vessel in a knock down................
Now, where are YOUR batteries...? $hit happens so please install your batteries safely. A little spilled acid, if you have flooded batteries, is better than a 65 pound cannon ball flying through your cabin.
I generally dislike the cheap battery hold down straps that come with plastic battery boxes. The AGM photo before this one is a prime example of sub par hold down straps, neither of them was still operable... These cheap straps, with their plastic buckles, are marginal to useless at best.
EMS, LL Bean or Northwest River Supplies (NRS) sell the type of canoe/kayak straps I use. They work extremely well and are very, very strong..
Mounting
Off Set Fill/Vent Caps
Here is a a prime example of a 12V group 31 battery (Deka/East Penn) that absolutely needs to be installed properly. If not they will leak on one tack and this leakage can quickly ruin the batteries..
Here the batteries are properly installed with the neg post facing PORT and the positive post facing STARBOARD.
I can not stress enough how critical proper orientation is with batteries that have offset fill/vent caps as these do..
4D Orientation
With 4D and 8D batteries the placement and orientation of cells is different than a typical 6V GC2 or 12V G24, G27 or G31.
In a 4D battery the cells are rectangular, as shown here with the red lines. As such the cells on 4D batteries are best mounted so the long length of the battery runs bow to stern. This puts the narrowest profile of each cell oriented to minimize positive and negative plate uncovering during sailing conditions..
The red lines represent the cell dividers inside the battery box. Each rectangle/cell is sealed from the others. The battery could also be flipped around so port / starboard are opposite the the long sides of a 4D should face port/starboard...
4D Orientation
8D = NOT OPTIMAL
In this image I have left the red lines off the cell divisions. If you look closely you can see the faint divisions of the cell dividers imprinted/dimpled into the plastic cover.
When you look close at the cell layout of an 8D battery you can clearly see that these cells are SQUARE! The 4D has rectangular cells, which can be better situated, the 8D really has no optimal configuration for a monohull sailboat.
Because of the square cells on an 8D battery there is no orientation that is better than another. Any way you install a flooded 8D battery, on a monohull sailboat, will result in the plates uncovering when heeled. This is never good for the batteries overall longevity.
Use 8D's at your own risk and if short life is an issue, and everything else is 100% correct, you'll know part of the reason.
8D = NOT OPTIMAL
Hope this helps.
This article is also on my web site here:
Faster, T37Chef, eherlihy and 8 others like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #2 of 13 Old 01-15-2013
T37Chef's Avatar
Re: Installation & Orientation of Flooded Batteries
thanks Maine...good timing
Shawn
T37Chef is online now
post #3 of 13 Old 01-15-2013
Maine Sail
I have just completed building the shelf/box for my battery bank this fall. This writing comes in the nick of time as I was planning to line the posts fore and aft. Great timing - thanks for this and for another excellent article.
SVTatia is offline
post #4 of 13 Old 01-15-2013
Maine Sail....Very interesting! Thank you for that great tutorial.
I've been procrastinating installing new hold down straps for awhile...I've never liked those white straps either. I replaced the old ones in kind, but knew I wanted a better solution. You've provided good incentive.
Can you describe what was done on that Sabre, I'm curious about the cable terminals on the left of the photo. The four stainless and two brass (?) terminals. What's being terminated there? That's a nice clean set-up.
Thanks Again.
tempest is online now
post #5 of 13 Old 01-15-2013
Señor Member
PorFin's Avatar
Unless I'm mistaken, the four stainless studs are the negative bus bar and the two brass studs are the shunt for a battery monitor.
________
'85 BYB Vagabond 39
PorFin is offline
post #6 of 13 Old 01-15-2013 Thread Starter
Maine Sail's Avatar
Bingo!
Maine Sail....
Thanks Again.
None of that is stainless. All the lug terminals are tin plated copper and the neg distribution bus bar is also tin plated copper (Blue Sea). The Brass you see is a 50mV 500A shunt for a Victron Battery Monitor. The two cubes on each POS battery post are Marine Rated Battery Fuses or MRBF's.. I did that install a few years ago when re-wiring the high current systems on that boat..
Tempest likes this.
______
post #7 of 13 Old 01-16-2013
probwhite's Avatar
Fascinating! I had no idea. Seems almost obvious now.
Pauly
I came off the rebound, started looking around,
Figured out it's time to have a little fun.
probwhite is offline
post #8 of 13 Old 01-16-2013
chef2sail's Avatar
Great post....Course with AGM you dont have to woory about this but they arent for eveyones use as we have talked about before
My new victron and all the battery fuses look like yours,,,,whew
BTW wheres the plastic cover that goes on the 4 post neg busbar?????
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #9 of 13 Old 01-16-2013
Learning the HARD way...
eherlihy's Avatar
Excellent post... Although, now I have another project!
Thank you!
T37Chef likes this.
eherlihy is offline
post #10 of 13 Old 01-16-2013
chucklesR's Avatar
Fortunately my battery storage location is oriented correctly, I don' t have to sell the boat.
T37Chef and chef2sail like this.
chucklesR is offline
Flooded Diesel Hilllman General Discussion (sailing related) 4 02-03-2011 02:30 AM
Orientation and networking mariano General Discussion (sailing related) 1 05-06-2010 03:09 PM
Need Help with a Flooded Boat! hArpOoN General Discussion (sailing related) 2 05-01-2009 11:01 AM
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 07:00 PM
Flooded battery installation questions windancer1 Gear & Maintenance 2 12-16-2001 05:03 PM
