Clean bottom how much? - Page 4 - SailNet Community
 9Likes
post #31 of 52 Old 01-18-2013
I don't discuss my member
Fstbttms's Avatar
Re: Clean bottom how much?
Originally Posted by dive7mmwet View Post
OK just not to bust your bubble if at a marina its so unsafe due to the risk of ! electric shock!
Of course one wants to dive safely, but it should be noted almost zero electric shock drownings occur in saltwater (where I presume the OP keeps his boat.) Almost all ESDs happen in freshwater. The OP is at far greater risk simply driving to his saltwater marina than he is diving in it.
Fstbttms is offline
post #32 of 52 Old 01-18-2013
blt2ski's Avatar
Originally Posted by Fstbttms View Post
So will you be allowed to clean non-copper ablative paints? Inquiring minds...
I have not heard frankly. My marina does not allow in water cleaning no matter the type, even tho state law allows cleaning of hard paints. They are a bit anal shall we say.........THey have even gone so far as to take brushes as I described off of peoples boats! I personally have a foldable/telescoping one that fits in the cockpit locker! I will hit the rudder and hull sides for the slime I get.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #33 of 52 Old 01-18-2013
Fstbttms's Avatar
Well, for what it's worth, the alternatives to copper-based paints are typically less effective than the products they are replacing, so if you need hull cleaning now, you will need it moreso when the copper ban kicks in. It might not hurt to make the marina aware of this. 'Course, this is all years down the road.
Fstbttms is offline
post #34 of 52 Old 01-18-2013
Wink Re: Clean bottom how much?
Don't forget, cleaning a hull at 'night' ain't easy you miss spots (I know), and IF you think the bay has any visibilty below a foot, ha. I have a 30ft hose, and leave the tank on the boat, just swin around, less weight. I've heard of people using auto body suction cups to stay in place while cleaning, cause it ain't easy to stay in one spot. .02
AirborneSF is offline
post #35 of 52 Old 01-18-2013
Fstbttms's Avatar
Fstbttms is offline
post #36 of 52 Old 01-18-2013
no longer reading SailNet
Alex W's Avatar
The fine for cleaning "soft/toxic" (so copper based abvalitive) paints in WA is $10,000:
Hull Cleaning and Boat Washing | Clean Green Boating | Washington State Department of Ecology
Pressure washing a boat on the lift typically has an $80 handling fee as well to divert waste water from sewers. Realistically it's hard paint or no cleaning here.
Alex W is offline
post #37 of 52 Old 01-18-2013
LOL. I don't like to try to clean my hull at the dock, as there isn't enough room, and the bottom gets stirred up being so close. More room under the hull, to me anyway, means less 'bumps' on my head from the hull,(guess how ya find that out), and the boat is ALWAYS moving. Maybe we should get a small floating dry dock, and use that to clean hulls.? .02
post #38 of 52 Old 01-18-2013
Sailnet Vendor
jblumhorst's Avatar
$2.25/ft plus $10 labor for each zinc. That's on San Francisco Bay for a narrow 27 footer with really good anti-fouling paint. With good paint, we on SF Bay don't get awful fouling. If I used cheaper paint, I'd expect to pay my diver more.
My 27-footer gets cleaned every 4 months when the paint is new, mostly just to check and replace the zincs. Oh yeah, I almost forgot: he has to scrape the critters of the prop, strut and shaft. That's one nasty job, I fear that probably should be done more frequently if I were really picky. I'm not.... I've got a three blade prop .
When the paint is 18 months old, it's needed every 2-3 months, and at 24 months it's time for new bottom paint.
My diver uses a very soft brush when he inspects the bottom. He's a careful diver. Never broke my transducers, like my previous diver. And keeps me well informed about the condition of my boat.
And, the best part? I don't have to spend a day doing the dirty work myself. Priceless.
The water is 50-65 degrees. Salt. I use Petit Trinidad Pro. The stuff is expensive but the bottom stays clean and the paint pays for itself in the long run.
On my trailerable, I'm going to try Interlux Fiberglass Bottom Kote Aqua. Sometimes I keep it in the water for a month or two at a time. It's a hard paint that stays active even when out of the water. It's not cheap either, but it has a great reputation.
Judy B
San Francisco Bay and Delta
J/70 - no name yet
Catalina 27 TR
Custom Antrim WWP19: "She's my Little Deuce Sloop, you don't know what I got" for pocket cruising anywhere my SUV will go.
Last edited by jblumhorst; 01-18-2013 at 01:20 PM. Reason: fixed errors. Matt knows my boat better than I :D
jblumhorst is offline
post #39 of 52 Old 01-18-2013
Fstbttms's Avatar
Originally Posted by jblumhorst View Post
I pay $2.50 a foot on my 27 footer...
I beg to differ, Judy. You pay $2.25/foot.
I get the bottom cleaned every 4 months when the paint is new... The bottom stays clean except for a little fuzz that comes off when we go sailing.
Again, I beg to differ. ;-)
Fstbttms is offline
post #40 of 52 Old 01-18-2013
Sailnet Vendor
jblumhorst's Avatar
Deleted.... because it's duplicate
Judy B
J/70 - no name yet
Catalina 27 TR
Last edited by jblumhorst; 01-18-2013 at 01:21 PM. Reason: how did I get two copies of the post?!?
How do you clean your bottom? paul323 SailNet FAQ 24 12-23-2011 09:35 PM
How to Clean a dirty bottom jephotog Gear & Maintenance 14 09-08-2009 11:55 AM
keel clean up and bottom paint hobie61 Gear & Maintenance 1 04-30-2009 07:51 AM
How do you clean the bottom? razorseal Gear & Maintenance 5 02-23-2006 12:06 PM
Diver to clean bottom..how much $ Wega24 Racing 5 08-19-2002 08:03 AM
