Frozen rudder shaft Hinterhoeller 28 - Page 10 - SailNet Community
 23Likes
post #91 of 196 Old 01-31-2013
Tartan 27' owner
CalebD's Avatar
Re: Frozen rudder shaft Hinterhoeller 28
Originally Posted by RobGallagher View Post
Give the Kroil time and maybe some passive heat to expand things. Can you get some heat lamps in there?
This is good advice: let the Kroil have a few days to work. Passive heat too.
Have patience and it will come apart peacefully. If you have no patience you can take it off in pieces, with a Sawzall!
Everybody has one:
CalebD is offline
post #92 of 196 Old 02-01-2013 Thread Starter
rbyham's Avatar
A quick progress report. No video but here is apicture of current status. As you can see one side of the shaft is now exposed down to top of rudder tube. I am tryign to preserve shaft (obviously) and tube. My hope is to see the stuffing box loosen as I dround it in Kroils. Will try heat tomorrow as well. So far no movement. Have used large pipe wrench on it but will not budge. The rudder is lashed form below in case it suddenly frees up. Any other ideas??? Thanks.
rbyham is offline
post #93 of 196 Old 02-01-2013
Now that you have it exposed, is there any likelihood of being able to dig out the old packing material? Is it truly solidified or a fibrous mush?
Faster is offline
post #94 of 196 Old 02-01-2013 Thread Starter
rbyham's Avatar
All indications are that there is no more packing in her. I cut one of the ears off whole giving me a cLear picture of the side of the box and I am down to aluminum. Now the kroil and heat need to work. I don't want to cut off more of box lest I have nothing left to get a wrench on. If I cut her flush to top of box and she does not free up my only option be to open the rudder which would necessitate fabrication of a new one. Something I want to avoid.
rbyham is offline
post #95 of 196 Old 02-01-2013
HANUMAN
RobGallagher's Avatar
Kroil, Kroil, Kroil and heat. I might not be apposed to two weeks of heat and daily Kroil re-application.
The key here is giving it time to penetrate. If it's locked up that tight it will take T I M E. There are many virtues in life, time and lubrication are at the top of most people list
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #96 of 196 Old 02-01-2013
Senior Moment Member
SloopJonB's Avatar
I'd start using that dead blow hammer and twisting the rudder back & forth like you described earlier.
Nothing too extreme - just firmly & steadily, alternating from one to the other.
If you can't get anywhere with that and the penetrant, a more serious attack would be to slit the rudder tube lengthwise and wedge it open. Then the rudder would HAVE to drop out (I think ). You could repair the tube simply by wrapping it with some layers of epoxy & glass fabric.
SloopJonB is offline
post #97 of 196 Old 02-01-2013
guitarguy56's Avatar
If you are down to aluminum and no more packing... I think you might be galling metal to metal and no amount of Kroil or heat is going to loosen that rudder... your alternative is brute force or cutting the tube to loosen it... it's unfortunate you put all this effort to finally have to resort to drastic measures.
guitarguy56 is offline
post #98 of 196 Old 02-01-2013
HANUMAN
You could be correct, but since there is no rush I would allow some heat for expansion, time, lubrication and penetration. If it does not work then at least we know all options have been expended.
I dated my first girl in high school for more than two weeks until time, heat, lubrication and penetration finally worked itself out. I think this boat owner can outlast my virginity
HANUMAN
'88 C&C 30 MKII
NOANK, CT
post #99 of 196 Old 02-01-2013
A little KY jelly never hurts (oops)...
Seriously... that would have to be a lot of heat... that's a large piece of metal to heat up and the heat sink is too much to warm anything up to expand... of course a torch might do the trick with some brute force...
post #100 of 196 Old 02-02-2013 Thread Starter
rbyham's Avatar
Got a torch. I do think I am down to aluminum and stainless shaft. What is galling? I can give it til about Tuesday at which point I getup against preferred splash date.
rbyham is offline
Cat 27 rudder shaft bushings harl Catalina 2 04-02-2012 12:56 AM
CS 36T rudder shaft log cptjak CS Yachts 1 08-29-2011 09:29 PM
Rudder shaft packing on a 34 johnharch Pacific Seacraft 28 12-03-2010 09:24 PM
Rudder Shaft Material hutch5151 Gear & Maintenance 6 11-05-2008 09:46 AM
Rudder Shaft Issues ranes Islander 0 11-03-2008 07:55 PM
