Frozen rudder shaft Hinterhoeller 28 - Page 13 - SailNet Community
 23Likes
post #121 of 196 Old 02-06-2013
Re: Frozen rudder shaft Hinterhoeller 28
Can you get your trusty sawzall down the tube now and slit that garbage at the top without damaging the lower bushing? I'm thinking if you cut a couple of slots vertically down to the tube wall you may relieve some pressure and then be able to physically remove the two pieces.. at least you'll have some limited space for movement and it may release.
Another possibility, though, if you're ultimately unsuccessful in removing that last bit, would be to cut the existing tube below that seal, then sleeve and extend the existing tube to where you need it.
That said, I do think you're making a bit too much of the job of replacing the tube.. as far as DIY glasswork project I think that's a fairly simple, straightforward task, esp if you can find an appropriate section of pipe or tube for the job. It would be easy to slip a temporary stock up there to maintain the alignment as you install the tube. You'd also avoid any future issues with whatever seized things up in the first place. You could also incorporate a socket for a new lower bushing that might be more easily replaceable in the future..
At any rate you're many steps closer to a solution than when you started... best of luck!
Faster is online now
post #122 of 196 Old 02-06-2013
Senior Moment Member
SloopJonB's Avatar
Originally Posted by rbyham View Post
BTW, the white junk in my hand is what I pulled out of the tube once the shaft was removed. Any idea what this is? I am guessing the inside of the tube between the bottom bearing and the old box had about 3/8" of this on side walls all the way around. Could it be some old packing that had completely disintegrated?
That mush looks like wet, thick aluminium oxide. I've never seen any type of packing that could end up looking like that. Is your rudder shaft aluminium by any chance?
I agree with Faster - I think you're making too much of what the job would be to glass in a new tube. Glass & epoxy work is quite simple albeit sticky & itchy. It is a skill you are almost certain to need during your boat ownership years. By the time you have done this you'll be fairly expert - it really is about that straightforward.
Trying to rebuild what you have looks like a LOT more work and expense to me and what you'd end up with wouldn't be as good - more complex, more expensive, not as strong and susceptible to the same failure down the road.
Your setup is unlike anything I've seen in a sailboat while what we describe is very standard practice and has been for decades.
SloopJonB is online now
post #123 of 196 Old 02-07-2013
I would like to see what the rudder / rudder shaft looks like after taking it out.
Have any pictures to post
knuterikt is online now
post #124 of 196 Old 02-07-2013 Thread Starter
rbyham's Avatar
Here is a shaft picture.
Also, if I glass in a new tube how is the top sealed? Ending at the quadrant would have it open above the water line so can it be open or am I needing to plan for a new stuffing box as well?
And with a new tube what actually holds the rudder up? The only thru-shaft would be the quadrant bolt. Originally there was a collar type piece with two allen headed screws one on each side that rode about the orig stuffing box and I assume functioned as a vertical hold on the shaft.
rbyham is offline
post #125 of 196 Old 02-07-2013
I think if the tube ends as high as you can get away with, the pressure on any seal there would be quite minimal - it shouldn't take too much .. Some kind of Oring might do.
As far as holding the rudder up I'd reinstall/create a pinned collar at deck level.
post #126 of 196 Old 02-07-2013
One of None
deniseO30's Avatar
Well.. if it's not been said... CONGRATULATIONS ON GETTING IT FREE!
Faster and SloopJonB like this.
My last project!
deniseO30 is offline
post #127 of 196 Old 02-07-2013
SloopJonB's Avatar
If the shaft goes high enough above the waterline you don't really need to worry about a seal. My Col 43 didn't have one and there was no evidence that water had ever intruded. The quadrant bolt and the tillerhead fitting will hang it securely. Put a ring of UHMWP or Delrin on top of the tube as a thrust surface for the quadrant and just let the rudder hang.
P.S. that pic appears to confirm my suspicion that the white mush is aluminium oxide. Is the rudder shaft aluminium?
post #128 of 196 Old 02-07-2013 Thread Starter
rbyham's Avatar
I have not determined the make-up of the rudder but my best guess at present is it is aluminum. So I think the guess at aluminum oxide is probably a good one. But I was surprised at how gooped up it was in there. I would say a full 4" of the tube all the way around at 3/8" deep was that junk.
In terms of height above water line, my measurements show a max of about 4" above water line for new tube. Any higher and I am running into the quadrant. My concerns are things like heeling and how that might impact.
rbyham is offline
post #129 of 196 Old 02-07-2013 Thread Starter
rbyham's Avatar
Thanks Denise. Yes that felt great!
rbyham is offline
post #130 of 196 Old 02-07-2013
You must check the lower bearing surface of the shaft, if it is uneven you must find a fix - one option is to add a sleeve, read more here: Jefa stainless steel and aluminium sleeves
I suggest you read this about sealing Sealing systems
Cat 27 rudder shaft bushings harl Catalina 2 04-02-2012 12:56 AM
CS 36T rudder shaft log cptjak CS Yachts 1 08-29-2011 09:29 PM
Rudder shaft packing on a 34 johnharch Pacific Seacraft 28 12-03-2010 09:24 PM
Rudder Shaft Material hutch5151 Gear & Maintenance 6 11-05-2008 09:46 AM
Rudder Shaft Issues ranes Islander 0 11-03-2008 07:55 PM
