Frozen rudder shaft Hinterhoeller 28 - Page 17 - SailNet Community
 23Likes
post #161 of 196 Old 02-15-2013
Re: Frozen rudder shaft Hinterhoeller 28
Originally Posted by rbyham View Post
Hows about this? ......
Will the remaining seal material/whatever that is still stuck in the top be cleanly removed?
Faster is offline
post #162 of 196 Old 02-16-2013 Thread Starter
rbyham's Avatar
Yes I would use a multi saw for a clean perpendicular cut just below where all that old stuffing box remnant it. I that would leave me with a clean new SS rudder tube but about 3/4" shorter. It is a very solid unit and everything would fit right back into the hull. With fresh bedding and glassing from inside it should be even stronger than glassing in a fiberglass tube . I would have to glass first and then drill new holes up through so bolts go in last.
rbyham is offline
post #163 of 196 Old 02-16-2013
Hinterhoeller HR28
pvanv1's Avatar
Rick... There's nothing wrong with your old tube, aside from the damage done by extracting the old seal. Yes, it was wise to extract the tube and inspect the connection/seal at the hull. I would re-fit the top seal (use whatever you prefer for that), re-bed it in 3M 5200 (very permanent!) or Life Calk (polysulfide), and be done with it. No glass needed -- none was needed for over 45 years, so why re-invent the wheel? KISS.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
post #164 of 196 Old 02-16-2013 Thread Starter
rbyham's Avatar
I tend to agree with you Paul. I think cleaning all surfaces and re bedding would do the trick. Glassing would probably be overkill. I am thinking a stuffing box like Denise shows above to fit to top of tube. Would be a fairly easy refit. Someone asked about a backing plate on outside of hull to create sandwich of hull but there was nothing of that sort originally. Just the four bolts up through the hull with washers and nuts inside.
rbyham is offline
post #165 of 196 Old 02-24-2013 Thread Starter
rbyham's Avatar
After a week on the road and all day rain yesterday I finally got a few hours in on the boat today. The stuffing box is in and fits well to rudder tube. I got the old stuffing box cut off the tube today as well. Then I prepped the hull inside for bedding tomorrow. The rudder shaft had a few nicks and corrosion spots but all sanded down well. So tomorrow we will bed the tube and then give it a few days to cure before putting the rudder back in. I one step at a time.
rbyham is offline
post #166 of 196 Old 02-25-2013 Thread Starter
rbyham's Avatar
Well some good progress today. See pics. Got the refit rudder tube bedded in Life Calk today. Was cool and windy but my faithful wife assistant hung in there while we got it all gooped up and tightened down. I plan to give it until Saturday to cure and hopefully reinsert rudder hardware. The job today went well though there was some minor panic as we had to work hard to get all four bolts to line up well. Probably used too much calk. :-) See pics.
rbyham is offline
post #167 of 196 Old 02-26-2013
Hinterhoeller HR28
pvanv1's Avatar
Looking good !
Paul Van Voorhees
Buffalo, NY USA
pvanv1 is offline
post #168 of 196 Old 02-26-2013
Irrationally Exuberant
Nice looking job! Your progress has been really impressive, rbyham. It's been interesting to watch you go from "let the pros have at it" to becoming a bit of an expert on this situation yourself. Well done!
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #169 of 196 Old 02-26-2013 Thread Starter
rbyham's Avatar
Thanks for the encouragements folks. I feel good about where we are with launch plan. Ultimately splash will tell the tale. :-)
But honestly I doubt I would have tried this repair apart from guidance and encouragement found on this forum. The HR28 is much less a mystery to me today.
I know you all have heard it before but a noobie is very appreciative and excited to meet more of the Charleston sailing community once I get into a slip. That and I cannot wait to get 8 years of storage grime off the boat and see what she can really look like. :-)
Our Colorado daughter is bringing a young man this week to meet us. I plan at this point to spend Saturday with him and my local son putting the rudder back in. Will be a good chance to hang out with our son who is very excited about the boat and get to know the new guy as he really is.
pvanv1 likes this.
rbyham is offline
post #170 of 196 Old 03-04-2013 Thread Starter
rbyham's Avatar
Well the stuffing box/rudder replacement job is done! Yep. I had two good helpers Saturday and with them pushing from below and me inside inserting box and quadrant on we got her all up in and buttoned down. Looks real nice. Took about 3 hours. I used 3/8" graphite rope. Testing the steering she goes lock to lock real smooth. BUT sad to say no pics yet. Hopefully this afternoon I will get back over for a final pic. Thanks for all the help here. Assuming it will be dry on launch this has been a good experience for me. I know the boat very well at this point which is a huge bonus.
NOW... this has me wondering about the box on the prop shaft. Stuffing there is vintage 2002 with boat on the hard since 2005. Should I open that box up and replace that rope? I have started the engine and run for up to 10 minutes. Feeling the shaft and box at t hat point they were mildly warm but no where near hot. And that on the hard with no water to cool. What do you think?
Again much thanks for all the guidance along the way. Man boatyards must hate you all! :-)
deniseO30 likes this.
rbyham is offline
Cat 27 rudder shaft bushings harl Catalina 2 04-02-2012 01:56 AM
CS 36T rudder shaft log cptjak CS Yachts 1 08-29-2011 10:29 PM
Rudder shaft packing on a 34 johnharch Pacific Seacraft 28 12-03-2010 10:24 PM
Rudder Shaft Material hutch5151 Gear & Maintenance 6 11-05-2008 10:46 AM
Rudder Shaft Issues ranes Islander 0 11-03-2008 08:55 PM
