Frozen rudder shaft Hinterhoeller 28 - Page 18 - SailNet Community
 23Likes
post #171 of 196 Old 03-04-2013
One of None
deniseO30's Avatar
Re: Frozen rudder shaft Hinterhoeller 28
I'd do the the shaft stuffing to. Or in my case I went for the PSS seal when we did the cutless bearing.
Faster likes this.
My last project!
deniseO30 is offline
post #172 of 196 Old 03-04-2013
Senior Moment Member
SloopJonB's Avatar
Originally Posted by rbyham View Post
this has been a good experience for me. I know the boat very well at this point which is a huge bonus.
That's what DIY is all about (as well as saving a few boat bucks).
As to doing your shaft stuffing, probably a good idea but be careful of the dreaded "as long as we're here we might as well...." or you'll never get launched.
SloopJonB is offline
post #173 of 196 Old 03-04-2013
Congratulations on your great progress. I hate to be a wet blanket but want to alert you to a concern about the potential for galvanic corrosion arising from your use of graphite packing in the stuffing box.
To avoid galvanic corrosion contact between dissimilar metals should be avoided. Further,the greater the difference between metals on the galvanic corrosion scale the greater the potential for corrosion. Graphite and alunimum are far apart. If your rudder shaft is aluminum and you use graphite packing you will likely experince coorosion of the rudder shaft.
Galvanic Corrosion, theory documents Galvanic Bimetallic Corrosion
Flax packing is a better choice in this situation.
Hudsonian is offline
post #174 of 196 Old 03-04-2013
One of None
deniseO30's Avatar
Shaft coupling is or should be grounded through engine ground.
My last project!
post #175 of 196 Old 03-04-2013
Hinterhoeller HR28
pvanv1's Avatar
Your option on the prop shaft packing. New wouldn't hurt...
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
post #176 of 196 Old 03-04-2013 Thread Starter
rbyham's Avatar
Thanks for the alert on galvanic corrosion. The shaft was actually determined to be stainless. Is grounding still advised in that case? If so how does one do that? No worries about wet blanket. This is a learn as I go and I want to get things right.
rbyham is offline
post #177 of 196 Old 03-04-2013 Thread Starter
rbyham's Avatar
Another question. If I decide to change stuffing in prop shaft box is that a right or left handed box nut and how do I tell for sure?
rbyham is offline
post #178 of 196 Old 03-04-2013
It will be a standard thread, I expect.. the lock nut should resist the tendency of the shaft to 'turn' the gland off if that's the rotation direction.
Faster is offline
post #179 of 196 Old 03-05-2013 Thread Starter
rbyham's Avatar
I called the manufacturer today on the GTU packing. They told me no problems on the stainless rudder shaft. I am thinking about leaving it and checking on it occasionally.
rbyham is offline
post #180 of 196 Old 03-05-2013
Graphite and SS are fairly close on the galvanic corrosion scale, therefore, the potential for corrosion is less than with graphite and aluminum, which are very far apart on the scale. Further, the relatively large size of the rudder shaft helps protect it from the graphite.
Cat 27 rudder shaft bushings harl Catalina 2 04-02-2012 01:56 AM
CS 36T rudder shaft log cptjak CS Yachts 1 08-29-2011 10:29 PM
Rudder shaft packing on a 34 johnharch Pacific Seacraft 28 12-03-2010 10:24 PM
Rudder Shaft Material hutch5151 Gear & Maintenance 6 11-05-2008 10:46 AM
Rudder Shaft Issues ranes Islander 0 11-03-2008 08:55 PM
