another how 2 clean 20 years of grime off mast? - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 01-18-2013
rugosa's Avatar
Re: another how 2 clean 20 years of grime off mast?
Originally Posted by MarkSF View Post
In the case of alodine and lacquer, isn't the no sanding instruction even more applicable?
You could completely strip rigging and hardware down to a bare spar, strip with lacquer remover, alodine wash with Scotchbrite pads, re lacquer. If your going that route new wiring and rigging would polish it off, and maybe some cool new lights.
Or you could wash it, and go sailing
rugosa is offline
post #12 of 15 Old 01-18-2013 Thread Starter
NO TO PAINT YUCK!
Ok wash it- it is! no wax , cool LED's big 10-4! wiring too,
Sailing yes!
Thanks all!
dive7mmwet is offline
post #13 of 15 Old 01-18-2013
Senior Moment Member
SloopJonB's Avatar
Originally Posted by overbored View Post
aircraft and airstream aluminum is alclad and has a layer of pure aluminum clad to the surface and will prevent corrosion and polish to a shine. the untreated aluminum mast will not polish up like alclad and after many years of exposure is coated with a thick layer of aluminum oxide which prevents further corrosion. sanding it off is not a good choice unless you are going to paint. if you don't want to paint than wash it and keep it clean and go sailing
I thought Airstreams were clad in sheet stainless steel? The Airstream club used to have their annual meet in the town I grew up in and I never saw aluminium oxide on one.
SloopJonB is online now
post #14 of 15 Old 01-18-2013
overbored's Avatar
I have never seen a SS airstream. The two I have polished were both alclad aircraft aluminum and where made just after WWII. the reason they clad an aluminum alloys with pure aluminum is so it has the strength of the alloy and the outside surface will not corrode rapidly. pure aluminum is very corrosion resistant but not very strong
"GOLD RUSH" PRINDLE 16
overbored is online now
post #15 of 15 Old 01-19-2013
If your mast is anodized try WD-40. It's very easy to apply, removes dirt and leaves a little shine. Simple.
Ronbo
ronbo1 is offline
Catalina 22s Good Years Bad Years TJ8187 Boat Review and Purchase Forum 2 03-27-2012 12:58 PM
how to clean bimini top? eSailor General Discussion (sailing related) 6 11-27-2011 07:59 PM
Best way to clean algae? captainfun Gear & Maintenance 10 06-14-2011 09:21 PM
Good Years and Bad Years MooreVOLS Boat Review and Purchase Forum 7 08-26-2010 11:04 AM
your boat for 2 years, my house for 2 years wantogonow Cruising & Liveaboard Forum 0 08-27-2009 04:42 PM
