another how 2 clean 20 years of grime off mast? - SailNet Community
 1Likes
post #1 of 15 Old 01-18-2013 Thread Starter
OK
this is some spot of contention and I have got so many different answers & ideas, thoughts, before I attach this clean and upgrade rigging and lighting on my unpainted aluminum mast this spring fresh water use boat, and NO PLAN'S TO PAINT!
1. can you use a plastic scrub pad to remove grime?
2. a good safe cleaner?
3. wax is it necessary?
4. sand vs polish?
dive7mmwet is offline
post #2 of 15 Old 01-18-2013
Re: another how 2 clean 20 years of grime off mast?
In helping you make a decision on how to enhance the appearance of your mast; may I direct your attention to doing what aircraft owners and Airstream travel trailers do:
Polishing - Vintage Airstream
Dick
Flybyknight is offline
post #3 of 15 Old 01-18-2013
overbored's Avatar
aircraft and airstream aluminum is alclad and has a layer of pure aluminum clad to the surface and will prevent corrosion and polish to a shine. the untreated aluminum mast will not polish up like alclad and after many years of exposure is coated with a thick layer of aluminum oxide which prevents further corrosion. sanding it off is not a good choice unless you are going to paint. if you don't want to paint than wash it and keep it clean and go sailing
MarkSF likes this.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 15 Old 01-18-2013
Originally Posted by dive7mmwet View Post
OK
4. sand vs polish?
The most common finish for non-painted masts and spars is an anodized one. This is a hard aluminium oxide coating, applied electrolytically.
If you have no corrosion and it looks decent, I'd leave it alone, apart from normal washing with a no-more-than-mildly abrasive sponge, and detergent (ie, dishwashing liquid, an environmentally friendly one if you are that way inclined)
You can wax it if you like, but it won't do the slightest bit of good.
MarkSF is offline
post #5 of 15 Old 01-18-2013
With all due respect 1985 and newer Airstreams are not clad and they do polish up just fine, just not to a mirror finish.
The more it is polished the easier it gets next time, and the longer it lasts.
Usually the first polish shine lasts about a year. The second lasts longer and so on, because you are reforming the surface, making micro fissures smaller and smaller.
Dick
post #6 of 15 Old 01-18-2013
I agree.
post #7 of 15 Old 01-18-2013
rugosa's Avatar
Can't speak directly to your C27, but some spars are not anodized, especially early production. Some were alodined for clean and etch then clear lacquered. At least that is what we did in the 70's. The option was matt black awlgrip, occasionally satin or gloss white, but mostly lacquered.
rugosa is offline
post #8 of 15 Old 01-18-2013
In the case of alodine and lacquer, isn't the no sanding instruction even more applicable?
Just wash it.
MarkSF is offline
post #9 of 15 Old 01-18-2013
johnnyquest37's Avatar
I have Charleston Spars and my maintenance schedule calls for waxing the mast annually. Can't remember if I picked this up from the spar literature or the boat owner's manual. I've never waxed the mast, but first I heard that it makes no difference. Is that based on the anodization or some other factor?
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #10 of 15 Old 01-18-2013
tommays's Avatar
If your about here you wash it and leave well enough alone or undertake a massive project
There is NO easy button on this one
I am not getting the impression your looking to get in this deep
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Catalina 22s Good Years Bad Years TJ8187 Boat Review and Purchase Forum 2 03-27-2012 01:58 PM
how to clean bimini top? eSailor General Discussion (sailing related) 6 11-27-2011 08:59 PM
Best way to clean algae? captainfun Gear & Maintenance 10 06-14-2011 10:21 PM
Good Years and Bad Years MooreVOLS Boat Review and Purchase Forum 7 08-26-2010 12:04 PM
your boat for 2 years, my house for 2 years wantogonow Cruising & Liveaboard Forum 0 08-27-2009 05:42 PM
